My Barn Yard
/ My Barn Yard #21
"sjerden: Looks like some kind of handle with a loop to hang it with."
I got thinking of what you said about a handle and loop and of old tools. Then I thought - adjustable handle on a scythe. So I looked it up on google. The loop would be to fit over the shaft of the scythe - half round stock, with a nut to tighten down the handle on the end. The collar is there to push up against the wooden shaft. There is no wear on the steel loop because it is against wood. I think the nut would be wrenched down to set it tight against the shaft. The indentations in the collar would lock up against the shaft and keep it from loosening. I don't have an old scythe handy to check this out.
That handle must have been laying covered in dirt (under an apple tree) for the last 80 years- long enough for the wood to completely rot away. So who lost the scythe handle! - In my nearby garden I've found an ox shoe, horse shoe, and a piece of a clay pipe. In the bottom of my 13' stone well, during a drought, I found a whole clay pipe stamped Glasgow (Scotland).
The videos brought back memories- we had a single row corn picker made of galvanized steel. (vintage 1940's?). The corn went into a corn crib and was ground into grain. One load, when not all the husks were stripped off, my brother and I had the job of shucking the rest of the husks before it could go into the crib.
/ My Barn Yard
I think your right. It does look like it could be the handle of a scythe.
/ My Barn Yard #23
I found this piece of hardware in the dirt when I was lowering/leveling my old driveway. I assume there was wood attached at one time. Old iron rusts and stops rusting. The threaded portion could have been hand forged from half round stock, welded and threaded. The collar piece almost looks cast. Does anybody have a clue what this could have come from? There is no wear on the iron that I see. It looks light duty, but utilitarian.
Looks like it come of of a scythe, the adjustable side handles.I should have read to the end before I posted.
Caterpillar C18 Industrial Diesel Engine - Serial N8F01109 - Arrangement 385-7728 - Pump Takeout (A63689)
Caterpillar C18...
Kubota GR2020G (A63688)
Kubota GR2020G...
1042 (A60430)
1042 (A60430)
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
2006 GODWIN GHP45KW-RC-45KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
