225 hydraulic leak
/ 225 hydraulic leak #1
MESSMAKER
Bluegrass,KY
DK4710SE
I just brought my tractor back after the forth time to the shop for a leak. They have been great about it , but I am a bit concerned. The leak is around the rod entrance for the shifter. They said it had 2 o-rings on it and that may have been the problem, but Bobcat info only shows one. They said it was a bit odd that the rod did not have a grove to capture the o-ring. It just kinda rides on the shaft. Anyone have any info on this?
/ 225 hydraulic leak #2
Photo in the service manual shows groove in the shaft for O-ring, but you have to remove the side cover from the transmission to pull the shaft out and see the O-ring groove. Did dealer remove this cover? and if so why did they not replace the shaft or check with Bobcat if there was no groove for the O-ring?
Dealer sent question to Bobcat to see if the grove is required. They were waiting to hear back. They were supposed to be in touch. I guess it is possible that a shaft without the grove could have gotten into the mix, but we will see.
It is still leaking. I would guess an ounce or two per day.
My wife has been on me for my spelling. Groove has two O's in it. Sorry
/ 225 hydraulic leak #5
Shaft like this are usually made in batch runs do if you had one make it through there are probably more out there. Hopefully the rest of them ended up in Kioti production :laughing: No offense Kioti guys, just kidding. It is something to keep in mind, if it was a missed machining step it could end up in either color.
/ 225 hydraulic leak #6
ya even red now :)
Update
Service manager is still waiting on info about the shaft. Said he will let me know as soon as he gets a reply.
(2) 9.5-24 TIRES W/8 LUG RIMS (A62130)
(2) 9.5-24 TIRES...
2020 CATERPILLAR 259D3 SKID STEER (A62129)
2020 CATERPILLAR...
2015 LeeBoy 8510C Asphalt Paver (A61567)
2015 LeeBoy 8510C...
UNUSED WOLVERINE SB78-78" ROCK BKT (A62131)
UNUSED WOLVERINE...
2017 Chevrolet Box 14FT Box Truck (A61568)
2017 Chevrolet Box...
2024 JCB 3TS-8TNA TELESKID (A62129)
2024 JCB 3TS-8TNA...
