Price Check Mahindra 8' HD Lift Type Cutter
/ Mahindra 8' HD Lift Type Cutter #1
amstaff
Mahindra 5530
Has anyone priced one of these units? Trying to get an idea of what they go for...
Thanks,
Amstaff
/ Mahindra 8' HD Lift Type Cutter #2
amstaff,
I have a Mahindra 10' brush mower pull type. Paid $4600 for it 2 years ago. It has the Mahindra name on it, but is mfg by Kodiak. http://www.kodiakmfg.com/ Looking at these on the Kodiak web site will give you all the specs and info you may be interested in. Be aware of the pto hp needed between a 3ph vs pull type. When I went shopping for a mower I was also looking at the lift type but when I saw the pto needs and the size I wanted the 10' pull was my choice and made that decision from the Kodiak web site. Either way you go, the Mahindra/Kodiak machine will do the job. This weekend we finished cutting 60 acres for weed control. Looks good when it's cut down to 3".
idaho2
/ Mahindra 8' HD Lift Type Cutter #3
Hey Idaho,
Do you have any pics of that freshly mowed pasture?
/ Mahindra 8' HD Lift Type Cutter #4
CTW,
Absolutely. Some taken by phone camera. Mostly cut down to 2" and the So. 40 was last cut 15 years ago!!!! Just bought that a year ago.
Idaho2
/ Mahindra 8' HD Lift Type Cutter #5
Good looking land there Idaho !!
Also, nice mowing job...:thumbsup:
/ Mahindra 8' HD Lift Type Cutter #6
Beautiful land there! I too have been looking at the Mahindra 10ft cutter. If your pulling it with a 5530 I certainly should have no trouble with the 7010 cab!
/ Mahindra 8' HD Lift Type Cutter #7
jwcinpk,
Thanks for the compliment and it'll look better with the 40 plus maples we have planted this past spring.
The Mahindra 10' will be a sweet unit attached to the 7010. The unit running at 540 pto rpm's will handle any small 3" tree. If it bends under, it will shred & dice the little buggers. Little noisy but keeps on mowing. We mow our land down to 2" for weed control but higher heights is always an option.
idaho2
/ Mahindra 8' HD Lift Type Cutter #9
CTW,
Idaho2
Wish I had that grass here right now,looks good aroung there:thumbsup:
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
DOOSAN G25KW GENERATOR (A60736)
DOOSAN G25KW...
Giyi Mini QA Auger (A60463)
Giyi Mini QA Auger...
Club Car Utility Cart (A55851)
Club Car Utility...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2020 John Deere 26G (A60462)
2020 John Deere...
