Hydraulic Oil Level Visibility
/ Hydraulic Oil Level Visibility #1
kattywumpus
Gold Member
Southern Maine
Kioti DK40SE with Cab.
Any ideas on improving the visibility of the hydraulic oil level for the DK series? The clear oil and shiny dip stick makes reading the oil level difficult.
/ Hydraulic Oil Level Visibility #2
I did clean, then heat the tip of the dipstick and applied a coat of black spray paint so that the paint did burn/cook on the dipstick. So far so good;)
/ Hydraulic Oil Level Visibility #3
Know what you mean. Took me a couple of times to get used to it but I just make sure I have a good light source so I can see the reflection on the flat part of the stick/blade. Get one of those LED lights that clip onto the front of a hat....that might help?!:thumbsup:
/ Hydraulic Oil Level Visibility #5
I'm surprised the dye isn't green...lol
Same deal with Kubota fluid, UDT and SUDT. It's basically clear. I took my dipstick and drilled a hole at the high mark and the low mark. The oil will bridge the small hole when full, very easy to see.
After the first change the holes were moot anyway. I refill with Chevron Synthetic fluid and it's already dyed red.
You could, with a little trouble, remove the rear cover and bore it for a clear level window. They are available from most machinery supply outfits like MSC in various diameters.
/ Hydraulic Oil Level Visibility #6
Auto Zone has small bottles of fluid dye in different colors :cool:
BUYERS PREMIUM & PAYMENT TERMS (A59912)
BUYERS PREMIUM &...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2022 EZ-GO ELITE...
