What is the best 2 cycle oil?
   / What is the best 2 cycle oil? #11
You dont need to use marine stabilizer anymore for ethanol . The right stuff is yellow.
new stabilizer on the market made for ethanol fuels
* Perfect for use in cars, trucks and small engines!
* Prevents corrosion caused by todays Ethanol blended fuels
* Helps remove water from Fuel
* Cleans fuel injectors, carburetors and intake valves for better, overall performance
* Recommended for use at every fill up
http://www.pimpedoutmower.com/fadeslideshow/images/EthanolStabil_Web-Image.jpg
STA-BILョ Ethanol Treatment http://www.goldeagle.com/products/10_oz_ethanol.aspx
   / What is the best 2 cycle oil? #12
I'm also a Stabil user -- the marine formula (blue, not red) is designed for gasoline that has ethanol, so that's the right stuff. Premium gasoline, because some of it goes in the chainsaw, and always name-brand oil: stihl, jonsereds, etc.
My understanding is the little bottles of 2-cycle have fuel stabilizers, but I still think using Stabil is a good idea. I've got no particular expertise, by the way!
Yep, the 2-cycle oil is supposed to have fuel stabilizers, but I use Stabil also. But I've never used the marine formula (the blue stuff). And (knock on wood), I've seen so many posts about the bad effects of ethanol that I figure it must be true, but so far I've not had any problem with it.
   / What is the best 2 cycle oil? #13
I use Amsoil synthetic 2 cycle oil and and 93 octane gas... seems to work best for me in all my 2 cycle equipment.
   / What is the best 2 cycle oil? #15
Another vote for the Stihl Ultra. We are lucky enough to have a local station that sells non-ethanol gasoline, otherwise I also use the Marine Stabil, haven't seen the Stabil ethanol treatment stuff yet.
   / What is the best 2 cycle oil? #16
I just bought a Stihl 2-stroke hedge trimmer. Stihl has a deal right now where they'll extend your warranty an extra year if you buy the 6-pack of their oil at the same time you purchase the tool.
I guess it gives them confidence you'll be using the right oil. If I only use it in the hedge trimmer, that 6-pack of oil will last the rest of my life!
I just mixed the still hp super with 1 1/2 ounces of stabil with 93 octane for my 2 gallon mix. I will probably switch to the ultra but I have 2 more bottles of the hp super....
   / What is the best 2 cycle oil? #18
Okay, so a little off topic here but a question. I have stumbled across 5 gallons of racing fuel. 103 octane? I know where it came from and how old it is. Does anyone know if this is safe for use in chainsaws and string trimmers mixed with 2 cycle oil ( I always use Sthil ultra also).
   / What is the best 2 cycle oil? #19
Mistake made on the octane, It is actually 112 octane. I'm thinking of haveing it mixed half and half with 93 octane. So 1gallon of 112 and 1 gallon of 93 mixed with stihl ultra oil mix. would this be of any benefit?
   / What is the best 2 cycle oil? #20
Use it up. I have mixed cam2 and VP 112 or 114 race gas up and ran it through chainsaws. Just make sure of your carb adjustments.
I found mixing regular 87 89 93 octane gas 50/50 with 112 or 114 worked best.
2016 John Deere Gator (A55973)
2016 John Deere...
2007 Ford F-150 Ext Cab Pick-up Truck (A53422)
2007 Ford F-150...
Cart (A55853)
Cart (A55853)
2014 MACK ELITE LEU613 GARBAGE TRUCK (A57192)
2014 MACK ELITE...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
20-Ton Hydraulic Bottle Jack (A55852)
20-Ton Hydraulic...
