ATV tire pressure
/ ATV tire pressure #1
dapper
Gold Member
S.W. Ohio
NH TN-65, Ford/NH 3430, Ford/NH 3930, Kubota zd21
Have the RTV900 with the atv tires on it. Specs call for this to have 20# air pressure. This seems high to me, seems like 12-15 lbs. would work better, but was wondering what pressure you all are using in you tires.
Thanks.
/ ATV tire pressure #2
What is the maximum pressure written onto the tire sidewall?
My mule uses 12psi on the rears and 8psi on the front tires.
/ ATV tire pressure #3
Thanks.
20# sounds about right for an RTV. On my Utility ATV I keep 9# in the front and 7# in the rear because they are radials. Of couse, depending on what your doing with it, tire pressure can change. In the winter I put 12# in the front to compensate for the 60" Moose ATV plow. When riding in the snow or muddy trails I reduce the pressure which increese the foot print. Hauling stuff or carrying a load calls for an increase in pressure.
/ ATV tire pressure
Ragkar, 28# max pressure is what is on tire, but I would have though something closer to the 12-15# range would have been closer for normal working pressure. I know I could reduce pressure, but don't want to void warranty on tire, only few months old. No problems, just seemed high.
96" X 20' TRI-AXLE TRAILER (A64280)
96" X 20' TRI-AXLE...
Grapple Rake Mini Excavator Attachment (A61572)
Grapple Rake Mini...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
2008 Ford E-450 Super Duty Ambulance (A61573)
2008 Ford E-450...
