Hi! I'm new here, please be gentle.
A lady down the road is selling a Ford 3910 and I went to look at it today.
The loader, pto, and rear hydraulics checked out, but I wasn't able to get in gear. I'm wondering if this is a tractor IQ test I'm failing, or if it's broken.
There are two shift levers, a gear selector and a hi-lo. I can engage either one fine, but if I try to put the other one in it grinds the gears and will not engage. I have the clutch, the pedal on the left side, pressed, but grind, grind, grind. I thought maybe the clutch was busted, so I shut it off, and engaged both gears. With the clutch depressed I can push the tractor. With the clutch released, I can't. I think this means the clutch is ok.
So, the $10,000 question: Am I an idiot, or is it broken?
Unrelated and probably irrelevant information. The tractor has 3600 hours and an aftermarket loader on it. There is a minor fuel leak at the injection pump. I "think" it's probably a line, but I have to drop the loader to verify. It's been sitting for a while since the owner's husband passed, but it started right up. She's offering it for 10 -12k negotiable including a disk, two bottom plow, box blade, kodiak bushhog, spike aerator and field ripper.
Thanks in advance for the help.
