mitchash
Gold Member
I am looking for a brush cutter for my Jinma 254, what would be a good size for this tractor and about what would one cost? Thanks
The fenceline concern is common, I understand that. But you might be surprised if you actually measure your rear track. A JM254 with original rims/tires has an adjustable rear track between 1070 and 1250 millimeters. That means the widest possible positioning is 49.2 inches.No way I would go with a 4' unit because it will not get anywhere near the wheel width.
Well, confidence in your tractor and your ability both come with time and experience. But experienced owners know that their tractors and mowers operate most efficiently when the engine RPMs are actually delivering 540 RPMS at the PTO. On your Jinma, that's about 2200-2300 engine RPMS. If I used a 60' rotary cutter - at a nominal 1400 engine rpms in L3 - I'd likely fall asleep from boredom, only to be awakened occasionally by the mower choking on grassI have an 08 284 on that I use a 60" bush hog that I ordered along with my 284, on flat pasture I use L3, going up or down hill L2. All directions the pto is set at 540 with the rpm around 1300/1500
pto is set at 540 with the rpm around 1300/1500.
//greg//
Right straight out of the owner's manual Chris.Not sure where you got your info
JM254/284;
wheelbase; 1050mm
front track; 900 mm or 950mm on reversed rims
rear track; four position adjustable from 1070mm to 1250mm
Don't know what you may have done since purchasing yours, but both my JM254s conformed exactly to those measurements above. I had mine set "wide", and a 60"' bush hog extended several inches past both rear tires. Mowing up close to a fenceline was no problem.
//greg//
