my bx-24 is running hot..
   / my bx-24 is running hot.. #11
Point of reference. My 3-month old BX2660, when mowing in 100 degree weather, runs with the temp gauge pointing far toward the hot end of the white "normal" range. I keep the radiator and screen clean. My dealer says it's normal, and it hasn't caused me any problems. But, if that were the gauge on my F150, I'd be nervous.
what your dealer has forgotten to mention is that WHERE is the thermostat location? :( right next to muffler with NO heat shield to deflect some of heat away from muffler.
   / my bx-24 is running hot.. #12
What you'll probably find is that the bottom of the radiator is getting plugged w/debris.
Fine chaff always finds a way to work past the two screens and get clogged in between the radiator fins.
You can expect the engine to run alittle hotter when the ambient temp gets into the 90's and higher but the cooling system is designed to properly cool the engine in these hotter temps, as long as it's moving enough air through the heat exchanger (radiator).
Chaff/debris hinders it.
Like has already been mentioned, if you have an air compressor get a long wand air gun that can reachdown in between the fan blades and blow the debris out of the radiator back towards the seat. I don't remove my battery, just the battery compartment screen and the radiator screen, then I usually blow the radiator out every 10 hrs (when I grease the MMM btw).
I can tell when the radiator is starting to clog up by how high the temp gauge shows after an hr or so of finish mowing. Blowing it out every 10 hrs works good for me.
When blowing it out don't use the highest pressure you can as you stand the chance of bending those fins. Set the compressor to about half full open and try it, adjust accordingly...
If one doesn't have an air compressor, a good leaf blower will work but the key is getting at the bottom of the radiator.
I wouldn't recommend a pressure washer for the same reason as using an aircompressor set at it's highest output, bent fins don't cool as well..... But if one uses one as the only resort, use a tip that minmizes the pressure.
If these BX radiators were bigger it wouldn't be so critical but since they are "just" big enough to do the job, keeping them debris free is the key to a happy diesel engine :D
Dave
   / my bx-24 is running hot.. #13
As a test open up the hood or remove the shroud around the engine to see if it doesn't run cooler, appears there is a restriction to air flow in the engine compartment.
   / my bx-24 is running hot.. #14
Just a comment about using a pressure washer. Be very careful that you do not fold over all the fins:ashamed:. Make sure the spray pattern is 90* to the radiator fins:thumbsup:
   / my bx-24 is running hot.. #15
I've never used this product, have no interest in the company, other than I do buy some Redline lubricants.
But I've read (in Hemmings' publications, or "Old Car," I believe) that it's popular in the collector car/muscle car community, especially when big engines get stuffed into small spaces....
Red Line Synthetic Oil - WaterWetterョ Coolant Additives
I don't know if this raises any warranty issues for you, either, so I'd say to proceed with caution, warranty-wise.
Let us know?
My Hoe
   / my bx-24 is running hot.. #16
Shroud on a Bx? You mean side panels or something?
   / my bx-24 is running hot.. #17
Let us know?
My Hoe
I have used this product and I did notice a reduction on the temp gauge but will it prevent an engine from overheating ummm....don't know. I think it was developed mostly for the racing world where only water was used.
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A51039)
2014 Dodge Ram...
TMA (A49461)
TMA (A49461)
2006 BOBCAT S130 SKID STEER (A51222)
2006 BOBCAT S130...
2017 CENTAURO TANDEM AXLE DRY BULK TRAILER (A51222)
2017 CENTAURO...
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
