john deer fuel pump
/ john deer fuel pump #1
cabrerac
"I have a John Deer LX 279 Lawnmower The fuel pump is spiting fuel through a small hole directly in front. This shouldn't be happening, any suggestions??? The mower woldn't stay running unless it was on choke, but now it seems to running fine.... except fo..."
/ john deer fuel pump #2
Sounds like the diaphragm is leaking. You'll need to either replace the diaphragm or the pump. Finding a replacement pump should be no problem - about $35.
Jim
/ john deer fuel pump #3
I agree with Jim Thompson's post about your problem, but I'm not sure about the replacement prices.
Here is where you can find the John Deere parts and prices.
When you enter your model number, use LX279 without the space!
A JD replacement for your fuel pump appears to be $129. I couldn't find a separate price for just the diaphragm.
You may find some 3rd-party replacement parts much cheaper at other places. Look up the part on the John Deere site, then Google the part number. Be aware that the 3rd-party replacement part may not be quite the same quality as a genuine John Deere part.
/ john deer fuel pump #4
Ted,
I think that only a few companies make those pumps so its quite likely that the exact replacement pump is available through Rotary or Silver Streak. The pump would also probably less if purchased from a franchised source for the engine manufacturer.
Jim
2002 FORD UTILIMASTER 4X2 S/A STEP VAN (A67148)
2002 FORD...
2022 21ft Scout 210 Dorado Boat with 2011 18ft Magic S/A Boat Trailer (A64557)
2022 21ft Scout...
2008 KOMATSU PC78MR-6 EXCAVATOR (A65053)
2008 KOMATSU...
CAMMOND 10' BOX BLADE ON WHEELS (A64278)
CAMMOND 10' BOX...
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
2011 Ford Fusion Sedan (A64557)
2011 Ford Fusion...
