At Home In The Woods
/ At Home In The Woods
Bill 55 said:
Obed just how long is your driveway? I have read the entire thread and can't remember you ever saying how far off the road you are.
Bill,
Our driveway is 900 ft long.
Obed
Finally we have a master bath we can use. Getting a properly working shower door was an endeavor. In May the first attempt at installing a shower door occurred. The door leaked at the bottom where the installer did not provide the threshold that should have come with the door. We ended up letting the company who sold and installed the door take it back. We didn't pay anything for it. We decided to buy a different door from another company and install it ourselves. With the expense involved putting in a tile shower, it really bugged me that the original shower door installation was obviously put in not square and plumb. Thus, we didn't want to go to the headache of having someone else install the door incorrectly.
My wife actually performed the installation. I just helped carry the door and hold it it in place. We made certain we had a threshold at the bottom of the door to prevent water from seeping out from under the door. Not having a threshold makes no sense to me.
The first thing my wife did was to purchase a chemical to help remove the silicon caulk that was left from the original door installation. Even using the chemical, she had to scrub and scrub to best remove the caulk. Removing the original caulk will help the new caulk to adhere to the tile. Next she filled in the holes drilled through the tile from the original door installation. Then she installed the threshold using only silicon caulk. You don't use screws to install the threshold because screw holes would provide a potential place for water to leak. She installed the door frame and then we installed the door. Lastly she caulked around the door frame.
Tomorrow we get to use the shower! I'm confident my wife's installation will not leak. Don't be confused by the shower pictures; we have two shower heads in the shower. One shower head is attached to a flexible hose. My wife wanted the hand-held shower head to make it easier to clean the shower. We have the controls in the shower to use either shower head or both. There is enough room in the shower for two people, as long as they are opposite sexes and married.
Locating the handheld shower head on the opposite wall from the main shower head was not part of the original shower design. We had originally planned to tap a flexible hose off of the primary shower head supply line. The two shower heads would have been located right beside each other. As part of the original shower plan, we installed blocking for a horizontally oriented grab bar, not a vertical grab bar. So the original blocking did not work when we decided to use a vertical grab bar to hold the handheld shower head.
After the walls were drywalled and painted we figured out we needed additional blocking to support the vertical grab bar we wanted to use. Therefore we had a worker cut a hole in the drywall behind the shower wall, install 2x10 blocking in the framing, and patch the drywall. My wife repainted the patch work. When it came time to install the vertical grab bar, we discovered that the new blocking had been installed in the wrong place. So my wife tore out the drywall behind the shower again, correctly installed the blocking, patched the wall, and repainted again. It took three tries to get the blocking for the vertical grab bar correct.
/ At Home In The Woods #3,224
Obed, did you buy the second door locally or internet. Looking for one like it and no luck locally unless I'm willing to pay more than the whole shower cost. Looks nice, wish I had it.
Thanks, Joe H
/ At Home In The Woods #3,225
totally concur, but I will bet your baby daughter will want to sneak in there with either of you willing to let her in.:D
/ At Home In The Woods #3,226
I like the light color of tile in the shower. We had a shower like that in a rental house at the beach last week, it was a dark blue tile, and you couldn't see in there even with a light.
your wife did a nice job installing the door.
Thanks, Joe H
We bought the second shower door from a local company. The cost was $485 plus sales tax. There was obviously no installation cost; we installed it ourselves. Our glass shower door is the "frameless" kind. A tile shower is extremely expensive. I seem to think we only paid $300 for our fiberglass tub/shower in the hall bath. The hall shower curtain rod was $15 and the shower curtain was maybe $20. The glass door for the master shower cost more than the hall bath tub/shower.
Obed
/ At Home In The Woods #3,228
Obed
I guess thats why my friend built his shower as a "walk in" type with no door. It has 2 shower heads with some other nifty waterfall type stuff. I didn't ask if the other stuff recycles or runs off of a pump or if it is all fresh out of the faucet.
/ At Home In The Woods #3,229
My absolute all time best shower door is... (drum roll please) NO door at all. The master bath room floor rises up toward the shower entry and then at the entry starts down again. There is no curb. Very little water besides what is tracked on our feet ever gets out of the shower.
Shower doors and or curtains are always a significant cleaning chore/challenge. Hard water is a problem, soap scum is a problem, mildew/mold tries to gain a foothold and on and on and on... I have radiant heat in the floor and walls of the shower (had it to do again I'd put it in the ceiling too!) You can do it electrically if you don't have a convenient source of hot water like I do (WaterFurnace geothermal heat pump.) This is LUXURY! Wanna go low cost? Put a bunch of heat lamps in the ceiling of the shower. Oh, by the way. you want an exhaust register in the shower to extract humid air before it gets out of the shower.
I prefer a remote fan as they are so very much quieter. In my case the shower register is "Yed" into the Energy Recovery Ventilation system which runs on low speed 24-7 to provide fresh air and exhaust stale air but will switch to a higher speed if the bathroom humidity rises above a humidistat set point.
Pat
Pat
Pat,
It sounds like you went all out in your shower. Do you have any pictures? We have an exhaust fan in the master shower exits to the outdoors. The fan is very quiet. I tested the fan's noise before ww installed it. I really dislike a noisy bathroom fan.
Our master shower would need to be larger to work with no door. Personally, we chose to not have a super large master suite. We don't spend much time in the bedroom other than sleeping. Our master BR, bath, and closet are a little smaller than most newer houses in the same price range as ours. I've seen lots of new houses with huge master suites but with tiny hall baths and kids' bedrooms. We opted for a nice sized hall bath and decent sized 2nd and 3rd bedrooms.
We also chose to put the bedrooms on one end of the house and the kitchen/great room on the other end to keep the sleeping areas as far from the noisy areas as possible. The current trend for ranch homes is a split BR layout with the BRs surrounding the LR/ktichen.
Our house is also basically a traditional rectangular shape to allow for a cross breeze, something not seen in most newer house plans because a rectangular shaped ranch house requires a lot with more road frontage than a narrow/deep house.
Our layout might seem a little more old fashioned compared to what is seen in the latest trends but it seems a little more practical for our wishes.
Obed
/ At Home In The Woods #3,231
Obed -
Liking your shower, and the wand for cleaning is a good idea. Think I like it more than this monstrosity we bought into.....:laughing:
Obed -
Wow! Did you attend a course to learn how to operate that thing? I'm thinking you should be able to stand in your shower and it would do all the washing for you!
Obed
Friday I took my tractor to the John Deere dealer to get the 400 hr and 500 hr maintenance performed. In addition, I had several grease fittings that would not accept grease so we asked them to make sure all the fittings would take grease and fix them as needed. Yesterday morning I went to pick up my tractor.
As I was loading the tractor onto my trailer, I noticed that the backhoe bucket squeeked when moving it. So I closely inspected the lube job around the backhoe bucket and did not see new grease coming out of some of the joints. I went into the shop and borrowed their grease gun. I then tried to lube the joints around the backhoe bucket and noticed that 3 of the 4 pins that hold the bucket would not accept grease! I then went to the FEL and found some fittings that also would not accept grease. I did not try all the grease fittings but concluded that I had gotten a very poor lube job. I suspect they did not have the grease fittings on hand and didn't want to take the effort to do the job right.
I unloaded the tractor and went and talked to the manager. He said they would do the job right and not charge me. Not happy. A while back I replaced myself one grease fitting near the BH bucket because it would not accept grease. After replacing it, it would still not accept grease. I imaging the area to be lubed was clogged with dirt and would need to be cleaned out, probably requiring the removal of the pin that was being lubed.
After the fact, I wish I had just taken the tractor and not left it there. But I did. Unfortunately, I had already paid the manager the almost $800 for the service before I discovered the lube job and grease fitting repairs were unsatisfactory.
More and more, I'm coming to the conclusion it is extremely difficult to get good work done and "if you want it done right, do it yourself". Fortunately we have a good auto mechanic that we trust. I hope he lives forever and never sells his business. I don't, however, have a good tractor mechanic.
In some ways, it might be quicker for me to do the routine maintenance on the tractor myself. Spending the time to schedule the maintenace, hitch up the trailer to the truck, load the tractor, drive 40 minutes one way to the dealer, wait in line, drive home, then do it all again when I pick up the tractor easily eats up 6+ hours of my time. Plus I have to pay for the work. My rationale for taking the tractor to the shop is to save time in my busy schedule but that doesn't always seem to work out.
/ At Home In The Woods #3,234
I think you are right on all counts.
You can buy a very good Lincoln rechargeable grease gun for ~$200, and all the other service should be just common hand tools.
You will save at least $500 the first time and $700 or so every time after that. plus you will know it was done right.
/ At Home In The Woods #3,235
+1, Sadly. Too many times I am disappointed in the same manner. I do just about everything myself as a result.
/ At Home In The Woods #3,236
Curly, why do you need a rechargeable grease gun? I use a hand lever grease gun and never had a problem lubing my Kubota.. do the John Deere tractors require higher pressure or ??
I agree though that you can save some $$ doing it yourself and be happy with the results or at least know who is responsible.
I do all my own service work, even rotate tires on the cars and trucks. Teaching my 3 daughters how to change their own oil, check and fill fluids, rotate tires, checking brakes is very satisfying.
/ At Home In The Woods #3,237
No john Deere tractors do not require higher pressure. But, once I tried a rechargeable grease gun, I would never go back. It is not necessary, but it sure makes a chore into something that is almost fun. The big deal is that I can hold the hose on the zerk with one hand and pull the trigger with the other.
If your tractor has only a few, easily accessible zerks then you can use a hand pump, but my backhoe has many grease points, with a lot in contortionist positions.
/ At Home In The Woods #3,238
I have always had better luck greasing right after use while pins and grease is hot, doing when it was cold would always create problems.
/ At Home In The Woods #3,239
Many good points... I too like doing things myself since I know I am not being cheated out of laziness. Problem is, some places WON'T honor warranty unless they service themselves or have no written proof of work been done. :thumbdown:
/ At Home In The Woods #3,240
Obed
We'll probably never learn how to use every function. The owners manual is barely legible. I've fixed numerous leaks on it. Just has a hose bust off that I need to replace. (for the foot massager :laughing:) The side spray jets feel like needle torture. jet pumps aren't working. But, the phone in the shower is pretty cool....:thumbsup:
Glad I didn't buy this thing, just the house it came in!!
Frank
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
2013 MERCEDES-BENZ SPRINTER VAN (INOPERABLE) (A60736)
2013 MERCEDES-BENZ...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
1973 White Trucks Western Star Dump Truck (A61165)
1973 White Trucks...
MULTIQUIP  LIGHT TOWER (A60736)
MULTIQUIP LIGHT...
2020 DRAGON ESP...
