International Cub won't start
   / International Cub won't start #21
soundguy
I am not familar with true surface. Can you give additional information?
   / International Cub won't start #22
since we are talking about trueing up a part.. then using a true ( flat ) surface is needed.
soundguy
   / International Cub won't start #23
soundguy
If you have a drill press handy, the steel table is pretty flat and is probably good enough to remove the uneven condition on that carb flange. Get a few sheets of 320 grit silicon carbide sandpaper and sand that flange smooth. You can finish with 600 grit.
Yes, I am now red-faced, but since it may help someone else, I'll confess. My Cub would not start, as the thread details. I even went so far as to pull the head and adjust the valves. Cylinders and valves look amazingly good. I put it all back together and still no start. In desperation, I went back to basics and checked spark timing for the nth time, and made sure again that the wires were on the distributor in the right place and order. They were not! I got them on right, and behold, it started. I still have no idea what the original casue of the problem was - unless some kind passerby swapped wires on me, and I guess that is possible. I guarantee that if it happens again, that will be one of the first things I look for rather than the last. And yes, I have now numbered the wires and the cap with white paint. AARGH!
-Ortis: a thousand years behind Sound Guy, but may someday catch-up a little.
   / International Cub won't start #25
glad you got it solved. that's the important issue.
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2001 CATERPILLAR CB-634C SMOOTH DBL DRUM ROLLER (A60429)
2001 CATERPILLAR...
2018 JOHN DEERE 35G EXCAVATOR (A60429)
2018 JOHN DEERE...
2016 Deere 180G (A60462)
2016 Deere 180G...
TANK MANIFOLD (A58214)
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
