Oil & Fuel rain water in fuel...:(
/ rain water in fuel...:( #1
BotaBX24er
SC
Kubota BX24
OK...made dumb move...filled up my tank and left the cap off for over a week...:( had several southern storms come on by during that time. I've only cranked it once but shut it right back down after i noticed the cap was off. Bought some Heet to put in, but what else should i do before i start it up and run it...do i need to drain it?
Any advice would be appreciated.
/ rain water in fuel...:( #2
Drain it
/ rain water in fuel...:( #3
Is it diesel or gas? If I remember Sothern rain storms then I would drain it and would be surprised if there was any fuel left in it. :laughing: :laughing:
/ rain water in fuel...:( #4
I would definately drain it completely, let it air dry for a couple days in the garage, put new diesel (assuming it's diesel) in it, then add some diesel stabilizer or something like it to get remaining moisture out.
/ rain water in fuel...:( #5
Drain it and refill to the top with fuel and add a water dispersant like Diesel Kleen. Keep and eye on the filter, or replace it on principle. I would.
Thanks for the heads up...called the repair guy (who was very friendly) and walked me through it step by step.
1) Since the water is more dense than diesel, it should all go to the bottom of the tank.
2) remove and replace fuel filter, which should catch the water if I have sucked it in while ran it for that little bit.
3) drain the fuel for a bit...water should come out, if there is any in there.
And for added measure, I dumped the Heet water removal additive in there. Since the filter was already off, I went ahead and installed an in-line shut off valve that i was able to pick up for $5 from the automotive supply shop
Oh, by the way, there was about a cup of water that came out in the mixture and it looked like i was really due for that fuel filter change too (225 hours).
/ rain water in fuel...:( #7
You should be good to go then. Now....remember to put the cap back on:laughing:
I have to make a disappointing update...after running it for about 3 hours, it started sputtering and misfiring and rpm's going all over the place while trying to drive. So I've gone ahead with a total drain and flush of the fuel system. Refueling with brand new fuel later on and will keep you guys posted.
/ rain water in fuel...:( #9
Next time do NOT put Heet in it, that is an alcohol and is bad for diesel fuel systems. Despite their advertising Heet does NOT remove water....where does it go? Into solution with the alcohol which is a bigger problem with a diesel than the water that was there in the first place IMHO.
/ rain water in fuel...:( #11
Does your Kubota have a water separator filter similar to my M4900? If so you need to monitor the level of water in it. Also some fuel conditioners have have water dispersal additives.
I can guarantee there won't be a NEXT TIME...first and last thing on my checklist now...:thumbsup:
/ rain water in fuel...:( #13
with proper maintenance, fuel conditioners are not regularly required...
I would drain the fuel system, maybe fabricate a long air blower out of a piece of copper tubing and a compression coupling and air hose connector... use it to blow around inside the tank.. then replace the fuel filter, put some fresh fuel in it. IF you feel the need to add something to the fuel system, dump a bottle of 2 stroke engine oil in the fuel... its one of the best simple lubricants....
/ rain water in fuel...:( #14
All the more reason for a Racor diesel fuel water separator filter as no water dispersant would be needed.
Did a complete drain of the system, new fuel filter and new fuel. Been running for over 3 hours without any problem now. phew...
/ rain water in fuel...:( #16
easier, gentler way to "pressurize" the tank, I've found, is to use the exhaust from your shop vac...put the hose on the outflow side of the vac
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
Great Plains 73290DH (A64126)
Great Plains...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
2019 Isuzu NPR 14' Box Truck (A62613)
2019 Isuzu NPR 14'...
Concrete Mixer (A62613)
Concrete Mixer...
