Post Hole Digger for BX25
/ Post Hole Digger for BX25 #1
TonkaToy
Member
Hey All,
Two questions on CAT 1 post hole diggers.
First, how are these for SCUT's? I rented a one man operated post hole digger and it did the job, but was a killer to use (45 holes and I felt it the next 4-5 days). I think I saw a post a year ago saying PHD for SCUT's were not that good, but can't recall exactly.
Second question, I don't have a big enough need to justify buying a new one (saw prices starting around $800 and up from there), any thoughts on second ones? Are these the kind of item that takes a beating and used ones are generally in bad shape, or they are good as second hand units?
Thanks
Franco
/ Post Hole Digger for BX25 #2
I have a NH TZ25DA SCUT and use a Woods PHD-25 and I'm very happy with it. I had no issues with power and I would think a used unit if in good shape would be fine.
/ Post Hole Digger for BX25 #3
Land Pride makes a PHD sized for the BX series. That's the way I'd go, just so the 3PH high/low position match the PHD.
/ Post Hole Digger for BX25 #5
I have the Leinbach 7200JR for my BX24 and it matches up perfectly. It came with a 9" auger and I then purchased a 12" auger and both work fine.
Unless abused, I see no reason to not buy a used one. If you buy used, as soon as you get it, I would recommend changing the gearbox oil just to make sure.
/ Post Hole Digger for BX25 #6
Go ahead and get one.....they do make digging holes easier.
Just be carful not to screw the tractor into the ground (You'll figure out what I mean the first time you do it:).
I wanted to thank everyone for the helpful info, it gives me some ideas and I'll see what I can find, thanks
/ Post Hole Digger for BX25 #9
And make sure you have a big pipe wrench on hand :)
(4) 12-16.5 Tires (A65640)
(4) 12-16.5 Tires...
Dickson Ind. 4080 SX Turbo Blast Asphalt Surface Prep Machine (A64194)
Dickson Ind. 4080...
excavator trenching bucket- one bucket per lot (A63689)
excavator...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
2022 EZ-GO ELITE...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2007 DRAGON 150...
