Hydraulic control valves
/ Hydraulic control valves #1
Scrub
Hi guys need some info for a school project On hydraulic directional contrl valves can anyone help please. I need the pros and cons and an application for each of the following directional control valve centres. Fully closed centre 3 and 4 port, fully open, tandem centre and pressure closed with A and B return to tank. Can't find much on the net any info will be much appreciated. Thankyou.
/ Hydraulic control valves #2
Closed center: (All four ports blocked)
Typically used with pressure compensated pumps or unloading circuit.
provide some load holding
Cons: Over time will allow a double acting cylinder to extend due to spool leakage.
Motor spool: Port "P" blocked, "A" "B" & "T" connected.
Also requires pressure compensated pump or unloading circuit
Typical use is for motors that are not required to hold a load in position or on cylinder applications with P.O. Check valves on the "A" and or "B" ports.
Tandem Center: "P" & "T" connected, "A" & "B" Blocked
Used with fixed displacement pumps
Typical use is for operating a double acting cylinder where some limited load holding is required.
Can also be used is a series circuit.
Open center: All the ports are connected
Typical use is for operating motors.
Cons: can not be easily used in a multiple valve system.
Roy
Thankyou oldnslo that infomation will be very valuable I appreciate your hel
/ Hydraulic control valves #4
Don't leave us hanging now. As you make some progress, keep us posted on this project.
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
17395SFL (A61568)
17395SFL (A61568)
Land Pride BB1560 (A62177)
Land Pride BB1560...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
