squeal in bathroom wall when outside hose on
   / squeal in bathroom wall when outside hose on
I had a similar issue one time and found that it was the anti-siphon fitting on the outside valve (the kind that screws on to the hose bib). Replaced it and the noise went away.
i hat those things with the darn install and break off setscrews.. makes a nightmare to remove them..
   / squeal in bathroom wall when outside hose on #14
I had simalar issue with my sisters house. I come to find out the bathroom sink cold water valve wasn't opened all the way. I just opened it up all the way and the noise stopped :thumbsup:
   / squeal in bathroom wall when outside hose on #15
Almost a 100% guarantee it's the anti-siphon causing the noise.
   / squeal in bathroom wall when outside hose on #16
If that's the same thing as a back flow preventer on the outside spiqot that would be where my I'd bet my money a well.:thumbsup:
yep.. bfp/as device same thing..
   / squeal in bathroom wall when outside hose on #18
But i think you should call any plumber he will solve your problem.
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A58214)
2014 DRAGON...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
Test Button (A55272)
Kubota M5-111 (A53317)
Rooster Weathervane (A55853)
Rooster...
