Comparison Turfs vs. Industrial vs. Bar
/ Turfs vs. Industrial vs. Bar #1
Scooby074
Super Member
Nova Scotia
BX 25, ZD 326
How hard are Bars on grass vs turfs and industrials?
How about traction on clay?
Im considering a BX25 and the dealer is really pushing turfs. He said that due to the rain this year people are wanting to go from industrials to turfs on their machines due to damage when turning. Where do Bars fall in there? Easier on the grass when turning, yet still grippy?
What about puncture resistance?
/ Turfs vs. Industrial vs. Bar #2
I went with Industrial because I use my L3700SUHST primarily for cutting brush and weedy woods. I have a lot of Mesquite trees and other thorny plants in my area and do not want to spend a fortune on tire repairs and service.
I do not have a "lawn", but rather have a country yard. My bermuda grass is slowly getting started, but tire marks in the dirt don't bother me as much as head high weeds.
I have had no issues with traction in my clay until I try to pull a 4" diameter tree out of the ground with a chain. I will dig in and spin a bit then. I do not have weights or loaded tires. I have not attempted this on wet ground as I am sure I would have less traction then. Dry clay will crumble into powder and reduce traction while wet clay is slick from the get go.
I have no experience with any other type tire on my tractor so I cannot give a comparison.
/ Turfs vs. Industrial vs. Bar #3
Industrials (R4's) are designed for operating on relatively hard surfaces, have very good puncture resistance, but traction on soft ground not a whole lot better than turfs. They will also damage soft lawns but not quite as bad as bars (I assume you mean mean Ags, or R1's when you say bars). On CUT's, Turfs are far and away the optimum tire type for operating on lawns and R1's are optimum in most situations off the lawn. Folks who need to use the same tractor on and off the lawn generally compromise in both situations by going with R4 tires. If you can swing it, you will be in for less dissapointment if you get seperate tractors for on the lawn (with turfs) and for off the lawn (with R1's). If you are limited to a single tractor, then R4's are more than likely going to be your best bet, and they are found on more than 75% of CUTs. Just prepare yourself for some lawn damage and some traction issues off the lawn. Personally, I would never consider R4 tires for any of my own tractor applications. I have (2) tractors dedicated to the lawn, each with turf tires and (4) for off the lawn, all with R1's. I am not someone given to compromise as is required if you try and use R4 tires for applications other than industrial for which they were developed. I dont want any damage on my lawn, and I want to always have the maximum available traction force from my tractors in field applications. R4's wouldnt provide me with that. I dont do any "industrial" work, and luckily, in 40 years of tractor operation, I have not puntured a rear R1 in the fields or woods on my farm.
I should have posted that this machine if purchased would spend 80-90% of its life as a mower.
Ive had industrials fill with clay.. no fun for sure:thumbsup: Not much better than turfs.
Current machine (x540) has HDAP's.. again not much better.
The "Bar" tires arent really like traditional ags (R1). Theyre pretty wide and the bars are shallow. as compared to narrow ags with deep bars. I guess technically they will be R1's. The tires im thinking of are a bit different than the pic. The bars are straight, with no curve
Ill try and post a pic if i can find one. Im hoping theyre a better compromise than industrials. without being too agressive
The tires in question are more like the second picture (single tire)
/ Turfs vs. Industrial vs. Bar #5
I would suggest you ask about "bar turfs" before you commit. Mine has R-4's, and as mentioned they are a compromise. Still, they do everything better than the alternatives for me (probably), but I saw a pic of bar turfs...a tire I didn't know existed and is apparently available on Kubota's and I'm pretty sure that would be a superior choice.
/ Turfs vs. Industrial vs. Bar #6
I have the Bar tires on my BX1850 and they have not damaged my lawn at all. I find the turf tires will spin easier and tear up the lawn quicker than the bar tires will. Tires are not filled nor do I have any extra weight on the tractor.
If the lawn / ground is real wet you may leave some lug marks.
Roy
/ Turfs vs. Industrial vs. Bar #7
I had BAR's, nice and soft and wide tires on my BX23TLB and mowed about 2 1/2 acres of grass,
(not golf course lawn). Never had a problem cutting up the lawn, mater of fact I do miss them as I have Industrials on my L3540 and I have to stay off grass when to wet and be careful when turning while turning when using fRFM.
DevilDog
/ Turfs vs. Industrial vs. Bar #8
what works for me I have R1 tires and our farm is rough terrian they work fine just dont spin em.any tire will mar up the lawn if they spin.
/ Turfs vs. Industrial vs. Bar #9
I've got bar tires on my SCUT, and they work fine on grass. Also comes in handy when I plow snow with it in the winter, sooo much better than industrials.
/ Turfs vs. Industrial vs. Bar #10
I have got hard clay and "bar" tires. Even when wet they don't tear up too much turf when I mow. And I do have steep hills too. I also am quite picky at how my lawn looks. I also use it around the farm and do some minor excavating with it and am very happy with the all around versatility of the tires. My tractor came with the Titan ag tires. I will get them again if they ever wear out!
/ Turfs vs. Industrial vs. Bar #11
My BX2200 had Bar and my BX2660 has Industrials and I really can't tell much difference.
/ Turfs vs. Industrial vs. Bar #12
My BX2360 and my L3130 both have R4 tires. For the most part there okay but if they ever need replacing it will be with bar tires.
/ Turfs vs. Industrial vs. Bar #13
I bought my T1510 with ag tires. They chewed up everything. go figure?! SO, I traded them for R-4 tires. I loved them until spring, they were horrible in the field and the lawn.... forget it. Now I have turfs. I wish I would have bought them in the first place. I live on a hill....... They close 1/2 my road in the winter hill...... and I have NO traction problems. Now, I don't pull a two bottom plow, or anything extreme, but for my mower, backblade,etc.... They work fine for me.
/ Turfs vs. Industrial vs. Bar #14
A few weeks ago I got a BX2360. Turfs, loaded with RimGuard. On the lawn, they are great and ride smooth. I have done some excavating with the loader and am happy with the traction. The weighted tires do a lot for traction, yet do not harm the grass.
I like the Carisle fieldtracs on the John Deeres, HDAPs. I wish that was an option on the Kubota, it wasn't and I did not want to spring for an extra set of rims and tires. (YET, LOL)
/ Turfs vs. Industrial vs. Bar #15
If it has a loader you will probably USE the loader ?
Ag tires are typically NOT rated for the full rated weight of the loader - so basically those are OUT.
Lawn damage is MUCH more a function of tight turns, wet soil and WEIGHT than tread pattern.
Back to that loader again, if you use it to anywhere near its capacity you WILL churn up lawn if you do tight turns.
Even without a loader you can churn up sod with turf tires by doing tight turns when the ground is wet - don't ask how I know this.
Against that I HAVE used my loader with turf tires on the front, they have looked about ready to roll off the rims and if one had I might have flipped - not a good idea.
On my little 42 HP Kukje tractor I have a set of loaded R4s and a set of unloaded turf tires.
I try to switch them to match the seasons, but it always seems that I put the turfs on too early in the Spring and/or dirt work crops up too late.
I usually get the R4s back on before turning over the gardens for the winter and setting up for snow removal - usually.
I don't see much of a case for R1s, unless you are doing row crops, but then you probably wouldn't be considering a BX25 (-:
Yeah, wet clay can stop just about anything/everything, so tread pattern hardly matters.
Best get something on tracks for that area, but even then.....
Seriously, a BX25 isn't a clay pit pony, what would you be doing in/on clay ?
Laying a tennis court, or something ?
/ Turfs vs. Industrial vs. Bar #16
As long as you don't crank the wheels all the way the bars should be fine on you yard.
R1s are great in clay and I think the bars would be about the same. We have never had any problems with punctures and unless you have a know problem (ie locust thorns) I wouldn't worry about it. All R1/bar tires I have seen are rated such that if you have them inflated properly they will be fine for loader work.
I would avoid R4s. On wet ground they are as hard if not harder than R1s (they have enough tread to rip stuff up like R1s but sometimes they will spin where R1s wouldn't and this rips it up more) They also suck in the mud and clay.
Turfs are great for golf courses and flat yards but are bad in the mud and clay. Also, if you yard is damp and not flat they are easy to spin which is very hard on the lawn. They are not really desined for loader work.
It sounds like the bar tires should work very well for you as long as you remember not to turn too sharp when mowing/working on the lawn.
Ed
/ Turfs vs. Industrial vs. Bar #17
personally i really do not care about how the lawn looks. but rather how fast i can get everything mowed. it might look rough. but it helps keep erosion down. and keeps the small critters away.
R1 tires to me = going through mud, and tires cutting through the mud down to harder surface and keeps you moving.
R4 tires (industrial) width of turf tires, and bars like R1s. to be honest there fat there big. and if you get into mud they can spin. fairly quickly. on a lawn. if you are out in that muddy / wet of a lawn. you shouldn't be out there in the first place with anything if you do not want to tear up the lawn.
Turf tires, to be honest, i hate them. granted majority of what needs to be mowed is on some sort of sloped hill. about only thing that is flat. is the fields. everything else is sloped a good amount. so being able to keep traction going up a hill is more important. even if it tears up the lawn. the lawn i have, it generally takes approx 3 mowings for any damage i have done to come back out of it and not be noticeable.
as far as other type of tires, including the bar type you noted. any tire going to tear up the yard if it is wet enough. once it dries, not a big deal. as others said turning causes most tearing up the grass. but wheel spin going up a hill can do pretty good damage. and be rather annoying. more so if you have to back down hill and go clear around and mow down the hill for each pass.
if tractor had 4wd drive or MFWD, i might choose turfs. but most likely it would perhaps turfs on the front, and R4's on the back. R4's in some spots more so low area spots were ground can stay mushy and wet for some time. it is nice to have wider traction tires. so you do not sink down into the yard leaving ruts like R1's would leave. **been there** the turfs on front. some times it might be nice to let the front tires slide a little in a turn vs trying to grab the grass and tear it out.
Reg : The clay in question IS the lawn :D There might be 1/4" of topsoil there under the turf if i looked close.
As soon as you slip a minute amount when its wet, the clay comes to the surface, packs the tires and its all over :laughing:
So far, it looks like Bars are winning. Assuming that they have the proper weight rating. They should be fine as theyre factory? Plus Massey offers the same tires as well.
What about thickness? Are these Sub CUT R1's thicker than industrials or turfs?
/ Turfs vs. Industrial vs. Bar #19
Ahh, gottit...
The ANSI standard "contractor lawn" level of top soil.
I believe 0.248 inches is specified (-:
A couple of years ago I dropped by the local sports field when I saw a couple of tractors in action, they weren't the usual mowers, which is what caught my attention.
They were reconditioning the baseball diamond, most of the baseball field and "laying in" fresh clay.
I think this is the only time I have ever seen ANYONE deliberately working with clay.
What was MOST interesting (to a tractor nerd) was the tractor tires.
They had golf course (Galaxy) turf tires on the rear and - wait for it - - used racing slicks on the front.
OK, OK, so they work on areas that are pretty much flat, but they were pulling box blades and rakes around, so needed SOME traction.
They NEED to make fairly tight turns, they NEED to not churn up the work area.
I don't know how they raise the pitcher's mound, I didn't stay that long.
They get the front tires for free, 15 inch rims and WIDE !!!
Not useful to most of us, I just found it interesting at the time.
As regards "thickness & toughness" of R1s vs R4s, the R4s really win out.
R4s are the "Construction site tire" for Bob Cats and Back Hoes.
R1s are the "Plowed and tilled field tire" for farming.
R4s can also take a LOT more fluid ballast due to their larger width, something like 55 gallons for the 17.5Lx24 R4s vs about 35 for the standard R1s on my smallest tractor.
40 more gallons total.. something like 440 lbs of total RimGuard ballast.
In SOME conditions the lower ground pressure due to additional width is GOOD for traction, you tend to "float over" mud and muck instead of "digging into" it.
The R1 will dig you out, but it is most likely the cause of the low ruts that have worn there anyway (-:
/ Turfs vs. Industrial vs. Bar #20
Old argument but to me turfs a worthless on a tractor. Its like putting street tires on a 4x4 truck. R4's are ok but do not hold a candle to R1's for traction. I have R1's on both my tractors and have used R4's on other peoples tractors and there was no comparison. I spend 1/2 my time in the woods logging and not one single flat with nearly 900 hours and 8 years. I also mow my 3 acre lawn. Its never been a problem. Just do not mow when its wet or make real sharp turns.
Chris
Skid Steer Trailer Mover (A65640)
Skid Steer Trailer...
MISC PALLET OF TRUCK PARTS (A65643)
MISC PALLET OF...
Towable Air Compressor (A64553)
Towable Air...
New/Unused Wolverine 78in Quick Attach Rock Bucket (A65583)
New/Unused...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
Portable Chicken Coop (A66408)
Portable Chicken...
