Mahindra Pricing??
/ Mahindra Pricing?? #1
RJJR
Gold Member
NC
2011 Kioti DK45 HST
I've been considering a Kubota Grand L 3940 and met someone this weekend with a Mahindra who spoke highly of the brand. But I've been on their websites and can't seem to find a pricing tool to compare models. Do they have one or do you have to call the dealer for all pricing? I'm trying to compare something close to the Grand L 3940. Does Mahindra have a model in this size with the telescoping arms like the Kubota?
Thanks
/ Mahindra Pricing?? #2
You might take a look at the 35 series Mahindras. Pretty nice machines and probably the closest to the Grand Ls that you will get from Mahindra. Yes they have the extendable ends on the draft links. You might be able to move up a size if you wanted and still be around the Kubota price. Just something to check on if you had a reason to go bigger.
/ Mahindra Pricing?? #3
I have a 4035. Paid around $23,000 for it. I looked at the JD, Kubota and Kiota. I sold a JD 240 skidloader with two hundred hours to purchase it. I have 337 acres and an outside woodburner and just found the skidloader not all that useful. I also live next to a river and use the tractor to put my dock and boats in. I could not be happier with the tractor. It is balanced very well and plenty of front bucket hydraulics. I have a tooth bar for it also that stays on most of the time. It is much more useful than the skidloader
How will the Mahindra be for parts availability? I've seen some folks say it takes 4-6 weeks for parts. Is that an issue to be concerned about?
Thanks
/ Mahindra Pricing?? #5
Thanks
I think that some of that is the dealer. I believe that just about any part is available in 3 days if YOU want to pay the shipping. I was just talking to my local John Deere dealer about how long it would take to get some parts that I might need. He said 2-3 weeks unless I wanted to pay for expedited shipping. So even the almighty JD takes some time to get parts. I have 2 Mahindra's, and have needed to get a couple of parts that my dealer did not have. I have never waited even 2 weeks for anything.
I would not let the parts time be a concern unless I was using the tractor to make my living, then it is a HUGE concern.
Good luck
/ Mahindra Pricing?? #6
I have two dealers within 40 miles. Hopefully they will have what I need when the time comes.
/ Mahindra Pricing?? #7
99% of the parts I put on a standard order, I recieve within a week. This is my experience over 9.5 years as a dealer.
Could you share the main differences in the 35 series and the Grand L series? thanks
/ Mahindra Pricing?? #9
I was shopping the Kubota 3940 Grand L, Mahindra and a couple of other brands. Went with the Mahindra 4035 - it was several thousand cheaper than the 3940 for the setup I wanted, has the extendable rear linkage, and a couple of other features the Kubota did not.
As for parts, my dealer said he can get them overnighted if needed.
8 days into owning the tractor, blew a hydraulic line due to some bolts not getting tightened in assembly at Texas plant - the salesman pulled the line from another tractor he had on the lot, drove 175 miles to my place on a Saturday, and installed it, NO CHARGE. He was at my place at 8 a.m. and gone before 9:30 a.m. Now that's service!
I'm very big on customer service and in talking with local Kubota dealers I left with the feeling like they thought they were doing me a favor by selling me a tractor. Only got that impression from one Mahindra dealer I dealt with, unfortunately he's the local guy. John Deere dealers were VERY helpful, but couldn't match the Mahindra prices and tractors had a lot of plastic on them and couldn't compare with weight.
Can you tell me the other features it has that Kubota does not? I'm trying to understnad what I'll be getting and what I'll be giving up if I choose the 4035 over the 3940. I may post this question separtately to get more feedback.
Thanks for your help.
/ Mahindra Pricing?? #11
Feature for feature, I think you can pretty much match them up equally if you're willing to spend the dollars.
As for standard features, I think the Mahindra comes with a cruise control and draft control standard, but the Kubota did not. Mahindra has a standard rear remote as part of it's price, not sure on the Kubota.
The seat in the Mahindra is the best I've ever sat in, I have been on the tractor for 3-4 hours at one time in rough terrain and wasn't beat up at all when finished. Just a GREAT seat.
The Mahindra hydraulics runs on a 11GPM pump and the Kubota implement pump is 8.9 - not sure that's an apple to apple comparison though.
I think the Mahindra was several hundred pounds heavier and cast iron through out in the frame.
It's tough to find comparison info in any one place, best thing to do is go to each tractor website and download the specs and make comparison that way.
I did find this website, it's not great but has info in one place.
TractorData.com - Tractor Compare
/ Mahindra Pricing?? #12
I think one of the biggest differences is in the transmission options. Mahindra is offered with shuttle shift, power shuttle, or regular hydro. Kubota has all of these plus the glide shift and the Kubota hydro is "HST Plus", which has features like stall guard and auto throttle. You can check it out on Kubota's website. Of course options cost money and the Kubota will likely be several thousand more. Take ranwin33's advice and compare the specs. You should also drive both of them and spend some time looking them over. You will likely find some small differences. For instance, I think Kubota hides the loader hydraulic lines inside the loader arm to limit possibility of damage. Don't forget to compare loader specs also and make sure you pick a good dealer.
/ Mahindra Pricing?? #13
That is some over-the-top great dealer service. I think it would be OK to mention the dealer's name.
/ Mahindra Pricing?? #14
The dealer is Straub International - they have seven locations in midwest Kansas. I would HIGHLY recommend them.
Email privately and I would be happy to provide the salesman's name.
He was very, very good. I prefer to deal by email so I always have a paper trail - and he was one of the few who responded quickly to each email I sent. We went back and forth for several weeks and he never pushed for a phone call.
Plus I think I got a heck of a deal.
/ Mahindra Pricing?? #15
The Kubota Grand L's with hydro transmission definitely do come standard with cruise control. I use mine all the time :thumbsup:
/ Mahindra Pricing?? #16
Thanks for the update, I couldn't remember.
/ Mahindra Pricing?? #17
That is a good dealer. I saw them the last few years out at the Topeka Farm Show. They always have a nice set up.
/ Mahindra Pricing?? #19
They have a reputation as an excellent dealer, so I am glad to see this.
I am glad to hear that. I just wish they would open up a store number eight closer to where I live.
/ Mahindra Pricing?? #20
I could be wrong, but that story sounds like a Bill story to me. Great guy to deal with. I am not sure where you are, but you can stop in any time you like for a tour of the plant your loader came from.
2018 INTERNATIONAL LT625 T/A MID ROOF TRUCK TRACTOR (A59909)
2018 INTERNATIONAL...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
New Leader MultiApplier Spreader Box (NEW) (A63109)
New Leader...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
