MF 128 hay baler
/ MF 128 hay baler #1
rizzyroo
mf hay baler 128
I have an MF128 hay baler, my problem is the metering arm which runs on a knurled roller keeps slipping when material is not going thru the baler. Why MF did not use gear on gear like JD I don't know. I have replaced the arm the roller checked clearances tried driving slow/fast but that constant plunger pounding espicially on turns the meter arm just vibrates down. To sum this up can this be converted to a JD style bale length metering system or does somebody got some ideas?
/ MF 128 hay baler #2
I'am not quite sure if its like the older New Holland's metering arm and wheel but I know on them you have to move the wheel ever so slightly {slotted holes where it's bolted to the bale chamber} to add a bit more tension on the wheel to keep it from vibrating down.Just thought I'd mention this in case it gives you something to check out on yours.Larry
/ MF 128 hay baler
massey driver
will give it a try, I forgot to mention I put a slot on the back of the arm and attacted a couple of rubber bands for tension, worked fine for 560 bales till by neighbor used it.
/ MF 128 hay baler #4
massey driver
Now that you mentioned about rubber bands I did a quick walk out to my old New Holland and its actually got a spring on the end of the arm keeping it tensioned to the metering wheel.But being a different make baler the massey could be set up different. Larry
/ MF 128 hay baler #5
Don't know if this will help, but here's a few shots of the metering arm on my MF124 baler.
IMG_0382 (Small).JPGIMG_0383 (Small).JPGIMG_0384 (Small).JPGIMG_0385 (Small).JPG
The knurling on the drive wheel looks pretty good, but there's quite a bit of wear on the metering arm knurling. I haven't used this baler much at all so I don't know if I'm heading for the type of problem you're experiencing. I just make the adjustments per the manual and go from there.
NexTier Frac Manifold T/A Trailer (A64194)
NexTier Frac...
215603 (A63276)
215603 (A63276)
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
Bush Hog Rotary Brush Cutter Tractor Attachment (A64553)
Bush Hog Rotary...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
HARDEE 300 GALLON PULL TYPE SPRAYER (A64278)
HARDEE 300 GALLON...
