Metal Power Tools - Remember Them??
   / Metal Power Tools - Remember Them?? #11
I have a couple saws, skill saw and jig must be close to 50yrs old now, if not more.
   / Metal Power Tools - Remember Them?? #12
A word of Caution, if you still use these metal handled tools, Be sure to check the cords. If a wire breaks it can accidentally electrify the handle. If replacing cords it is best to add a grounded cord to it. Plus be sure to use a grounded extension cord. These old tools have claimed a lot of lives>> Just 2 cents.
   / Metal Power Tools - Remember Them?? #13
The 1 speed saber saw works just like it did when new.
Had one of those .... sold it when we moved .... kinda wish I still had it.
   / Metal Power Tools - Remember Them?? #14
Good advice there, THANK YOU for adding it. I started to say something about not wanting those old metal cased power tools because of the shock hazard. With a metal case, it should be easy to attach the ground pin on a newer cord.
Just wondering here, if you had the old 2 wire metal power tool plugged into a GFI outlet, wouldn't that provide protection in most cases if the hot wire in the tool shorted out?
I am such a Nervous Nellie around power tools, I won't use my newer double insulated ones on anything BUT a GFI outlet.
Gonna tell you guys a funny story, yes it's funny now. When I was younger and dumber, I had a Craftsman circular saw with an on-off switch that would stick. And to make matters worse, the blade guard would sometimes stick too. But it was MY tool and I knew about the hazards. Well, one day my brother came over when I wasn't home and borrowed the saw...he was using it to cut trim boards on the floor. Well, he cut thru a 1X6 with the saw, set it on the floor, and the blade guard stuck, AS DID THE ON-OFF SWITCH. The saw traveled across the brand new vinyl floor, ripping a groove in it, until it ran over the extension cord and lost power.
From that day on, I either repaired or junked any power tools that malfunctioned in ANY way before using them. NEVER AGAIN will I use one that is unsafe.
   / Metal Power Tools - Remember Them?? #15
As a young lad I had the pleasure of being a carpenter's gopher. I was on my first jobsite helping raise walls when I was a mere 4 yrs old. My sole job was to make sure the studs were on the line. I tried to help position a door buck, but it weighed more than I did and put me on my ***.
I was perhaps as old as 8 or 9 when I was given the task of helping the lead carpenter cut a roof. My job was to had him whichever tool he needed. His saws were all Milwaukee or Skil saws with the full metal housings. One morning we were working in knee high grass which was full of dew. Everytime I picked up one of the saws I got shocked and dropped it quickly. After 5 or 6 shocks, I got courageous enough to refuse to pick it up again no matter how much the carpenter cursed or yelled.
After he became disgusted at me and picked it up himself I was sent to the truck for screwdrivers and electrical tape so he could repair the short. :thumbsup:
   / Metal Power Tools - Remember Them?? #17
People have been killed by 110v through tools?
Heck yes...I have experienced both 110 and 220 shocks and usually 220 will knock you back while 110 will hold and kill you....
   / Metal Power Tools - Remember Them?? #18
Can you imagine what a case a child labor law attorney would have had in your situation?
   / Metal Power Tools - Remember Them?? #19
I remember metal power tools. Maybe the ones we used to have were cheap, but today's tools are much better, IMHO. I would not go back.
   / Metal Power Tools - Remember Them?? #20
If you are well grounded, as in laying under a house and drilling a hole. Then the tool or cord fails, it could be as fast as a hairdryer in a bath-tub. .While getting shocked hard, it is hard to talk or holler for help. If it is strong enough you will taste copper or your tooth fillings in your mouth. It only takes a little current in line with the heart to be fatal. I like the new double insulated tools, plus they seem to be built stronger and better designs.
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2023 Kubota U55-5R1 Mini Excavator (A56435)
2023 Kubota...
2005 Jeep Wrangler 4X4 SUV (A56859)
2005 Jeep Wrangler...
2000 INTERNATIONAL 4700 (A58214)
2000 INTERNATIONAL...
