Finding a short in buried cable.
/ Finding a short in buried cable. #1
Surgeon
Vermont
MF 1428
My well is a shallow well 1000 feet from the house. The well guys tell me that there must be a splice in the underground cable that has corroded as they cannot get 220v to the well. The current cable is a high quality 4 wire underground cable that is deeply buried but not in conduit. They say it is unlikely that anything happened to the cable itself and that because of the distance that it is very likely the cable was spliced and that the splice is the problem. They say that they cannot find the splice and that the only solution is to bury a new cable. The well guys are honest but TBNers are a clever lot so I figure I would ask: Anybody know of a way to figure out where the splice/fault might be so I do not need to get the excavator to bury a new cable?
/ Finding a short in buried cable. #2
Get an electrician with a fault locator and he should be able to locate the fault within inches and give you the depth as well.
/ Finding a short in buried cable. #3
A Time Domain Reflectometer ( also just known as a TDR or cable radar) will find it in a heartbeat (local phone tech. or cable tv tech) might be able to talk one into helping you. If it is an open, you might not be able to do any good with a digital Ohmmeter. But I would try all combinations of the wires from both ends to see what I could learn anyway with that method. If its direct burial, or in PVC a cable tracer (signal on one end, and hunt with a pickup loop along the route) might be able to locate where the signal stops. But if you can get your hands on a TDR that is the way to go, will usually locate it within a foot or two. Good Luck
James K0UA
/ Finding a short in buried cable. #4
By 4 wire Im thinking you have 2hots, neutral, and ground. I wonder why you need the neutral for a 220 well.:confused: ... Anyway, do you have a short between 2 wires that should be insulated from one another - or open wires that should conduct end to end but wont? The difference is important. A short between 2 wires can be found with low tech pretty accurately by applying a precise small voltage to the 2 shorted wires and determining the current that flows. You would do this from one end and then the other. Unless the short is dead center the currents will differ and by that proportion will tell you which way from center and how far. If the problem is an open wire I think the open can be found by pinging the wire electronically and listening for an "echo" caused by the discontinuity at the open place. The timing of this echo would tell the position. You need a friend at an electronics lab - or maybe the power or phone co? One that deals with RF transmission should have the equipment for either scenario.
larry
/ Finding a short in buried cable. #5
SPYDERLK,
Good answer, because it is common for people to say "I have a short" when they mean "I have an electrical problem".
I think it is probably an "open" (a break in the line). Otherwise the OP (original poster) would probably have mentioned tripped circuit breakers or blown fuses.
Given that, I would support all of the responses about having someone use a TDR (Time Domain Reflectometer device that can locate a break) find the break. I just saw the sale of a used TDR on eBay for $150. Surely you can have someone check for a break for less than the cost of replacing the 1000' line.
I agree that the problem is most likely at either end, or at a splice in the middle.
Personally, I set a post where there was a splice in my line, and buried a lot of aluminum cans not too deep directly above the break to make it easy to locate with a metal detector in case the post disappeared over the years.
/ Finding a short in buried cable. #6
X 2. Fault locating isn't hard to do, you just need the equipment. I used to do quite a bit with a unit like this before I retired.
It could be a bad splice, but it could also be a case of insulation failure, either a pinhole from when it was manufactured or possibly damage from handling or it could be damaged by something it was buried with, like a sharp rock. A fault to earth won't necessarily trip a breaker, the earth resistance can be high enough that the breaker sees it as just a load...I've seen that happen. Several years ago a guy called in that there was steam rising from the ground out in his back yard so we went out and checked. Sure enough there was a hole in the snow and a small pool of water in the lawn, maybe 6 - 8 inches in diameter and it was bubbling merrily away...electrolysis, eh? It did warm it up enough to raise the temp high enough to thaw the earth and melt snow but it definitely wasn't boiling...I checked after the power to it was shut off. Turns out the previous home owner used to have a pool house out back but had torn it down and filled in the pool before he sold the house but they didn't remove the electrical service to it, just buried the bare ends underground. They probably just opened the breaker and left it like that but the new owner turned it back on not knowing what it fed but thinking it had to be on.
/ Finding a short in buried cable. #7
this may not work in your situation, but I was amazed at how it worked for me. I found a break in my Invisible Fence wire quickly with a cheap pocket radio and an "rf choke" from Radio Shack. I put the rf choke on the transmitter and waved the radio over the rough location of the wire till I found the break. It was cheap and fast, maybe some variation of this will help you.
How to find a break in an invisible dog fence
/ Finding a short in buried cable. #8
Problem with using a TDR is that most of the newer units are set-up for a select VOP Velocity of Propegation. I have an old Tektronics 1502 that would get you within twenty feet each side. Proglem is I would have to coem operate it for you.
Don;t know where you are located, but if you have a smaller electric coop near you call and talk to them and ask them if there is a contractor around that can thump faults for you. Basicly they charge up a large capacitor and throw the switch the fault shows up real well and they then can TDR the wire or look for a hole in the ground.
USing a small AM radio will find it also Get the line located energise then tune to the low end of the spectrum and walk along the line. When you hear the buzz get louder you are near. At the loudest point should be your leak RF travels straight up thru the earth.
/ Finding a short in buried cable. #9
I had a similar problem last December with direct bury wire. Well just stopped working. Fault locator guy said "dig here, it's 36" deep" and when we found the wire there was no visible damage. Could have been pinhole, as Mace suggested. He used a gadget similar to what Mace showed in his pic to locate the "fault". I wasn't convinced the fault was there, but maybe it was.
Well guy gave us temporary power, but said our tank was also bad.
I paid an 18 yr. old kid to dig a new ditch (I'm 67 yrs. old and it rained every day with temps around 36F and a wind blowing--it was worth it to pay the kid), then I laid the conduit and had one of my buddies from the Air Guard who is an electrician and works cheap but not free, run new wire. Then the kid filled in the ditch.
Wire (a big expense, copper isn't cheap these days), conduit (cheap), labor (the kid, the well guy and the electrician), new tank, etc. for 110 ft. ran $1,800.
For the distance you have to go it looks to me like a repair job is in order rather than replace like I did. There were lots of good posts on TBN on how to splice the line.
/ Finding a short in buried cable. #10
A pinhole in the insulation can be the start of the problem but by the time things quit working, the conductor will have corroded off and the fault is usually quite obvious, moreso with aluminum conductor than copper. When copper conductor is almost all corroded away, the little bit left heats up from the current flow from the load and sometimes from flow to earth and usually causes the insulation to melt enough to be obvious. Aluminum turns to aluminum oxide which swells considerably and makes the fault quite conspicuous.
Fault locating is more an art than a science sometimes. Darn machines lie to you! :D
/ Finding a short in buried cable. #11
Well said and the Aluminum wiring turning to oxide, means an open in the line. It can also steam from moisture...Aluminum or copper can be repaired, and sealed using heat shrink tubing.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
MASSEY FERGUSON 2605 TRACTOR (A64276)
MASSEY FERGUSON...
Hydraulic Breaker Excavator Attachment (A61572)
Hydraulic Breaker...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
