Kubota ZD326P Value??
   / Kubota ZD326P Value?? #1
jcdogfish
Louisiana
Mahindra 2516
I am thinking of putting the 326 for sale and going back to a tractor. Any thoughts on the value appreciated. 2007 with 212 hrs. Great shape
   / Kubota ZD326P Value?? #2
My dealer sells a new ZD326 for 11.3K if that is any help to you.
   / Kubota ZD326P Value?? #4
Why are you getting out of the ZD ? Where area are you ?
I had a boating accident and the shoulder is giving me fits on the zero turn. Tractor rides a bit better and can turn it with one arm. Also have a garden. It will add a hour or 2 on the cut time. The zd is a grass cutting machine.
   / Kubota ZD326P Value?? #6
If your time is of monetary value you may want to contact a Kubota dealer about trading your Zero to a Kubota F2680 (F3080 if you need 4wd). If your zero worked you probably don't need a 4wd. The F models are the ultimate mower that has a steering wheel and service is very accessable.
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
MAXUM M-1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM M-1000...
New/Unused 20ft Farm Metal Driveway Gate (A48837)
New/Unused 20ft...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2014 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2014 MACK GU813...
