Post Hole Digger
/ Post Hole Digger #1
HitchCL
JD
Looking for a quality Post Hole Digger
Id like it to be able to take larger augers to be able to work with large sono tubes for decks, etc.
I have priced out several different brands through local dealers and this is what I came up with. All of the prices include the machine, a 9" bit, a 12" bit, and a stand.
Shaver 601H
Takes 4-24" Bits
about $1600
Worksaver 500
Takes 6-12" Bits
about $1600
Frontier 300
Takes 6-30" Bits
about $2100
Land Pride PD 25
Takes 6-18" bits
about $2100
Again, these are priced with 2 bits and a stand included. I am leaning towards the Shaver, but a dealer has a Land Pride already in stock.
Has anyone used any of these brands? Any opinions?
/ Post Hole Digger #2
I picked up a Leinbach with a 9" auger. Will take pretty much any size auger as long as you have the HP to run it. Remember that the larger the bit the more HP is required.
/ Post Hole Digger #3
I can tell you from personal experience that the quality of the hole you drill will be in direct relation to the soil your drilling. Here in north Idaho a 9" drill works OK, but a 12" is a real pain in the $$$$ to use. most if not all small tractors don't have power down on the 3 point hitch, so they just tend to float over rocky or dry clay soils. Some makes (like my Speeco.. have a hydraulic down-force assist that helps. If your going to do this for a trade/business, most people use a front loader arm mount post hole digger that can be powered down, either on a skid-steer or a compact tractor. The skid-steers have higher hydraulic pressures and volumes to drive these units. Most tractors require a pto operated pump to power a front mount drill properly. There are some low volume drills available, but i don't know how well they work.
These front mounted units are kinda spendy though. If i had to do it all over again, i would have bought one years ago.
/ Post Hole Digger #4
I have a Land Pride PD35, the PD25s big brother. After putting a down pressure kit on it, it has dug all holes painlessly. I have 5 different bits ranging from 6" to 24" and all sizes work easily to full depth. My land pride info says that the PD25 handles 6"- 24" augers. I think that your dealer may be wrong about only going up to 18" with the PD25. ;)
/ Post Hole Digger #5
I have a Bush Hog 2102 with the stand. I have both a 9" auger and a 12" auger with Bearclaw replaceable teeth. It uses both these augers with ease. This is a heavy duty unit with the option to add hydraulic down pressure later if needed. Post Hole Digger 2102
/ Post Hole Digger #6
you probably have nicer soil than we have here. I have decomposed granite below 10" of the surface. Lucky dog. I just added my hydraulic assist, but havent drilled any holes with it yet....
/ Post Hole Digger #7
We do have nicer soil here. A big rock here is about the size of an apple and they are far and few between. I used to live along an old river bed. The post hole digger would go about 12" and the remaining 24" was dug by sledge hammer using a spud bar as a chisel. I don't miss that at all. I have spent a couple of hours digging each and every post hole.
/ Post Hole Digger #8
Yup...that sounds like my place. You should see the old auger i just replaced. about 1/2 of the metal has disappeared...warn away. My 9" holes were getting down to 6" diameters.
/ Post Hole Digger #9
I would have two friends standing on each side with a chain looped around the top of the spud bar to hold it straight while I hammered for hours with a sledge hammer. When we bought our new place non-rocky soil was at the top of my list. I put in 2,500 feet of new fence in the soft soil here by myself. It was so much easier I thought it was fun!
/ Post Hole Digger #10
I hate you...hehe.
It has taken me several years to fence and cross-fence my treed 20 acres. I have about 4,000 feet of field fencing in-place that Ive had to do all myself. I made a nice attachment that attached to my old JD tractor that held the rolls of field fence and they unrolled while i drove forwards..saved countless hours of work.
/ Post Hole Digger #11
I have always fenced by myself also. Fencing is one of the few things that I enjoy doing and try to do it well. I ripped out 2,500 feet of the worst fence and poles I have ever seen and replaced it with all new poles and No-Climb horse fence. This fence is still tight as a banjo string and is very pleasing to the eye after four years. I may be a little demented. The first thing I look at when I drive by a nice farm is how well the fence looks.
/ Post Hole Digger #12
100% right on. Our soil is rock with some clay and black stuff on top someone may call top soil. I hired some Mennonite gentlemen to put a deck on our house 2 summers ago. The brought a digging bar, manual post hole digger and a gas powered tow behind auger. It was a sizeable rig. We managed to get one of the 13 holes down about 6 inches. We literally broke the auger rig. That was after an all day slog with the 4 of them and me trying to make a few holes in the ground. I had to go out and rent a skid loader with an augar AND a hydraulic jackhammer attachment. Even with that set up I had a heck of a time. Downpressure is a must, unless you live in an area where rocks don't
/ Post Hole Digger #13
I have always fenced by myself also. Fencing is one of the few things that I enjoy doing and try to do it well. .
Vaaaaat....you crazy or sumpin?????:laughing: :laughing::confused2:
/ Post Hole Digger #14
if you have any bushhog dealers close by id look at their PH diggers.we bought 1 last year with the 9in an 12 in auger with bear claws on them for less than a $1000 new.
/ Post Hole Digger #15
If you have rocky soil out there you might want to consider a hydrauilic front loader setup. My soil is so bad that you can't stick a shovel in the ground without hitting something. I had to use a pick to edge a mulched tree ring the other day!
Before I bought my hydraulic auger I had to dig holes with the backhoe and spud bar. Standard 3-pt augers don't work here. Neither do post drivers.
I recently purchased a Belltec H-300 with Carbide tipped 9" auger mounted to my backhoe:
Problem solved.
-mark
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
