Generator Onan 25kw Generator
/ Onan 25kw Generator #1
mcanik
Member
British Columbia, Canada.
Kubota BX25
I found a steal of a deal. One 25kw Onan PTO generator for a dollar. It is an older model but if it works it is definitely worth travelling the 700km to pick it up. My question is, I have a 23hp BX25 Kubota and would like to know if I can run this generator at ~ 10kw with my machine without any problems:confused:. Thanks in advance for your valuable input. :thumbsup:
/ Onan 25kw Generator #2
Yes you could spin 10kw worth easy. The real question is who/why would someone give it away for $1, and is it single phase 25kw?
The real question is who/why would someone give it away for $1?
It is an estate sale and the tenant needs to move and is looking to liquidate everything fast. I am not sure if it actually works and will not know until I hook it up and try it. In order to do that, I need it here. If it works, I may be able to trade it for a smaller unit.
/ Onan 25kw Generator #5
The could get more than that just for the copper:)
/ Onan 25kw Generator #7
It will work my only suggestion is to change out the breaker on the generator to be more in line with your tractor's output other wise you will stall out the tractor if it does go to full load.
You could put the correct sized breaker in the transfer switch too that might be easier.
/ Onan 25kw Generator #8
Using the accepted formula 2hp per kw, you will get 1KW for every 2 PTO HP. So if you have 20 PTO hp yes.
There is some thoughts on running a larger genny at lower capacity, It's about the fly wheel effect, spinning mass staying in motion. Better to take 10 KW out of a genny with higher capacity than squeeze 10 kw out of a genny rated for 10 kw max. There may be a trade off though taking less than half it's capacity, taking up HP to spin it.
JB.
/ Onan 25kw Generator #12
I think a BX model is a little light for it. I see on northern tool supply a 27KW PTO generator for tractors of 48HP and up.
/ Onan 25kw Generator #13
I have Generac PTO 25 and a Ford 1720 with 23 pto hp and my tractor runs it fine and powers the whole house including the 5500 watt dryer, well, fridge, freezer & any other device at the same time.
As was said the KW produced is dependent on the pto hp of your tractor which in your case will be 8 to 10 kw.
The flywheel effect will also help with surge from larger loads such as deep well pumps, & other motors.
This will be a great back-up and you will be able to power the whole house with little or no restrictions on electrical load.
tim
/ Onan 25kw Generator #14
If it can be fixed up at a low enough cost it would be a bargain. I wouldn't over think this too long or someone else will have it. Free items like this will go fast.
/ Onan 25kw Generator #15
When you guys are connecting these units to earth grounded circuits are you making a earth ground at the generator?
I'm probably starting a war here, but a buddy I grew up with was electrocuted by a PTO generator that went hot through the tractor and I have called these things widow makers ever since.
/ Onan 25kw Generator #17
You are correct it needs to be grounded to the house ground to prevent electrocution and proper operation and protection of the house electrical system.
There should be a ground lug on the generator frame for this purpose. I attached a 20 ft heavy guage ground cable and clamp to mine for grounding purposes.
Tim
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
10' Fork Extension (A64912)
10' Fork Extension...
2015 CHEVROLET IMPALA (A66091)
2015 CHEVROLET...
23.1-26 Tires - Set of 2 (A68134)
23.1-26 Tires -...
2018 Ford Transit 150 (A64911)
2018 Ford Transit...
