JD 140 steering box
/ JD 140 steering box #1
Rbslh
John Deere 140
Can you rebuild a steering box on a 140. I can take a lot of the play out by adjusting it but it is realy warn out. Additionally the idler arm has a lot of slop on it. Does it have bushings the replace? Thanks for the help
/ JD 140 steering box #2
:welcome:
There are some parts that may be available for the steering gear, but you best look them up in jdparts to see what they are (or visit the Deere dealer to see what is available). Noticed there was a bearing kit, and some bushings. Will depend on what is worn and what is available.
Thank you for the help.
/ JD 140 steering box #4
I just replaced the bearings on my 216 steering column. The JD dealer only had a bearing kit available.
2018 MACK CXU (PINNACLE) (A63569)
2018 MACK CXU...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2014 FREIGHTLINER CASCADIA 113 S/A DAY CAB TRUCK TRACTOR (A59912)
2014 FREIGHTLINER...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
John Deere Rear Wheel Weights (A64047)
John Deere Rear...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
