my cub bugs down and runs speraticly
   / my cub bugs down and runs speraticly #1
benschreffler
cub cadet 108
my cub cadet runs spits and sputers when i put a load on the engine when i give throtel .if i put it in third gear or run the deck wile the rpms are up it dies any ideas what this could be
   / my cub bugs down and runs speraticly #2
Maybe not getting sufficient fuel.... try cleaning filter??
   / my cub bugs down and runs speraticly #3
If engine is a twin, one cylinder may not be firing. check by pulling one plug wire at a time. listen for drop in rpm... Also replace Plug(s).
If engine start to pull/run better as you begin to apply choke, yer prolly due for a carb cleaning session. Take carb off, apart, soak(immerse) in carb cleaner overnite, use magnifying glass and run thin copper wire thru all SMALL holes/orifices, blow out all holes and parts surfaces with compressed air, re-asm using fresh carb rebuild kit. Do not re-use any gaskets. Name of the game is to work clean.
Case VAC Tractor (NOT RUNNING) (A50775)
Case VAC Tractor...
PALLET OF 2" X 4" STEEL TUBING & SITE PANELS (A54757)
PALLET OF 2" X 4"...
Scag Mower (A50324)
Scag Mower (A50324)
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
Horse Weathervane (A55758)
Horse Weathervane...
