JD 3020 cat 2 to cat 1 attachment?
/ JD 3020 cat 2 to cat 1 attachment? #1
MNBobcat
Hi All,
I may pick up a used Wallenstein BX-42 chipper tomorrow. The Wallenstein site doesn't say if its cat 1 or cat 2 but I'm pretty sure its cat 1. My 3020 diesel takes cat 2.
I have a farmer friend who said you could buy the stuff to adapt a cat 2 tractor to run a cat 1 implement. Before I buy this chipper, can someone confirm I can get an adapter? If so, what all do I need (pto and pins?) and do you happen to have a rough idea of cost?
Thanks!
/ JD 3020 cat 2 to cat 1 attachment? #2
/ JD 3020 cat 2 to cat 1 attachment? #3
I had the same problem when I bought my current tractor. Picked up a few sets of the adaptors mentioned above and they work great and are cheap. You could also buy cat 2 pins for the chipper, if the ones on it are removable, if you never plan on using it with a cat 1 tractor.
Sounds like its much simpler than I anticipated. I thought perhaps there was a difference in the PTO shaft/coupler as well.
If its only a set of bushings it doesn't get much simpler than that!
Thanks!
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
John Deere 661R (A64912)
John Deere 661R...
2015 (INOPERABLE) FREIGHTLINER CASCADIA (A67714)
2015 (INOPERABLE)...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
2017 John Deere XUV825M S4 (A64912)
2017 John Deere...
