pats quick change question
/ pats quick change question #1
closs2sx
i bought a set of pats quick change ends for my 4240 that has the sliding ends and they look great except one problem. the hole in pats quick change ends that the pin goes through (the original pin that holds the sliders in the 3pt arm) seems to be about .100" too big and has alot of slop is that normal and ok to use or should i have the hole made smaller. the pin dia is 5/8 (.625) the hole in pats ends are .810 should be .750 or 3/4 in my opinion. has everyone just used them as is ?
/ pats quick change question #2
Probably fits as good or better than Kubotas
/ pats quick change question #3
same on mine but with the u bolts and the locking bolts that help secure them to the 3pt hitch they are working just fine for me.
/ pats quick change question #4
Call Pat's with the question. They are very helpful and responsive to customers.
When I ordered mine for the sliding lower arm ends there were a lot of measurements that needed to be sent to Pat's for them to custom build it (or at least to make sure it fit correctly).
I sent them all my measurements and when I got them I called them and they said they would make a set with a smaller hole but I am just trying to see if they are all like that and if so are there any ill effects from too much slop to save shipping back and forth and save them from having to make another one if not needed. The only thing that holds mine on is that pin and with all that slop I was wondering how they wear
Morbark M12RX Wood Chipper (A63689)
Morbark M12RX Wood...
STEPP SEALCOATING MACHINE (A59914)
STEPP SEALCOATING...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
(16) Kinze 3000 Seed Boxes (A65640)
(16) Kinze 3000...
2021 BOBCAT E50 EXCAVATOR (A63276)
2021 BOBCAT E50...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
