Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,058
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I think we finally narrowed it down.
Setup: basement utility room/bathroom. Washer/dryer are in this room. The kitchen was originally going to be directly above this room and as typical, my wife decided to move the kitchen midway through building the house :confused2:
After the house was done, we noticed some septic smells... long story short, it turns out the drain for the washing machine (which is located INSIDE the 8" blocks) had a vertical pipe and this pipe was going to be the drain for the kitchen sink which would have been located essentially, directly above.
This pipe stub was (guessing) a 2" pvc pipe. It extended up about 5' from the drain of the washer and basically, only went through the block at the top of the wall and through the plate (2x8?) that was on top of the plate.
Unsure what to do, I figured I needed to give it some volume of air and also keep it closed. The geography of the setup totally disallowed me to vent this outside since I now have french doors directly above and my back patio on the side. This is a log house so I don't have hollow walls to deal with either.
I got maybe 40' of 2" pipe and inside the ceiling, snaked it from this stub across the room, into the other larger room and merged this pipe into what is the drain pipe for the kitchen.
Since this is an 'air' pipe, I held (mounted) it as high in between the joists as I could and when I merged it into the kitchen drain pipe, it came to this pipe from above.
Meaning, water draining from the kitchen could NOT enter this pipe since it angled up at that junction. This way I would never have an obstruction.
Enter today: we are still getting some septic smells in this room. It comes from this closet where the washer/dryer are located.
I'm now wondering if the fumes are coming from this newly installed vent pipe.
I suppose I could have installed a 1-way valve (??? don't know)
I just hate the idea of a valve being installed in the walls where I might not have access to it if it ever failed.
What is also making me scratch my head is why isn't the P-trap on the washing machine doing it's thing?
Last night, I had to pull the washer out to clean the input screen to it. When I put it back I noticed the actual drain pipe from it seemed to be pushed WAY down in the P-trap.
Is it possible to have the outlet hose from the washer too far extended into the P-trap, such that the velocity of the water from the hose will help create air movements through the trap??
Could pulling the drain pipe out one or two inches help keep a plug of water in there?
As best I know, there are now NO other open pipes what so ever. This is accurate unless the installer has an open stub INSIDE the block wall that I've never seen. Although I suppose that's possible, I don't see that happening. I'm 99% convinced it's coming from the P-trap
