BX25 hydraulic leak-control valve (manifold)
   / BX25 hydraulic leak-control valve (manifold) #1
jwatt51
Wilmington,MA.
2015 Kubota B2620
I noticed hydraulic fluid under my tractor when it was on my trailer.It was dripping from under the floorboard,so I followed it to the hydraulic control valve (manifold) which is right below the battery box.After reading posts here on TBN,I called my dealer and brought it in for repairs.I told him I seen that on TBN there was a service bulletin issued for the problem and he showed it to me. He said he'll order all the new lines and o rings for it and install them. My tractor is still under warranty,so thats good.I guess it's quite a job to change out all the lines.If it wasn't for posts on TBN,I would have gone crazy looking for a loose conection or a broken line somewhere.
One reason I posted this was to let anyone know who owns a BX25 or any other model that falls under the service bulletin and is still under warranty,is to check for any leaks from the manifold and have it repaired while still under warranty.From what I was told at the dealer is that the ROPS have to come off,the floorboard has come off and the battery case has to come out,which has many other things attached to it.
   / BX25 hydraulic leak-control valve (manifold) #3
Does the recall memo list a mfg date or serial span for suspect tractors? I bought one in Feb.
I don't know if it had a date or ser.# I bought mine in July 2010 and it's covered
   / BX25 hydraulic leak-control valve (manifold) #5
I know when I bought my bx24, the dealer said the hyd on the FEL was a PITA to work on...
Good to know...
2013 FORD F750 26FT BOX TRUCK (A51219)
2013 FORD F750...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
1985 Toyota Pick Up Truck (A50515)
1985 Toyota Pick...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
