snapper rear engine rider
/ snapper rear engine rider #1
heehaw
russellville, arkansas
Kubota M4900, B7510 and RTV
i bought another used snapper rear engine rider: this one has a 14hp kohler, an i got it from the guy that bought it new..in fact, i was with him when he bought it @ 1996: i just mowed with it for the first time, an it starts, runs, and mows fine: but i have got to put new covers on both axles: i have done this once before, many years ago, an seems like its not a lot of fun, but not extremely hard to do either...i've had probably 10 mowers like this over the years, never bought a new one....an usually get a lot of years use out of each one..with very little trouble.
heehaw
/ snapper rear engine rider #2
heehaw
I have one of these w/ a 16hp twin briggs. Rolled it 3 times on my steep yard. I have one bent axle. These things take a beating, but keep running stong.
i have two like this, with 14hp kohler engines, an two that are a lot newer, with 10hp briggs engines: i think they are 30 inch cut: never bought a new one, but have had a lot of them...the first one i had was a comet 26: it was like a brush hog...had a 7hp briggs on it: the wife uses the ones with the 10hp motors, because everything works on them an they handle pretty easy: i use the other two, because the brakes don't work on one, an the other steers like a tank...i have worked on the brakes many times, as well as a couple shops, an they still don't work...have not started working on the steering problem yet...
heehaw
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
12 Ton Hydraulic Jack (A64127)
12 Ton Hydraulic...
2021 Peterbilt 579 (A64127)
2021 Peterbilt 579...
Lockers (A62613)
Lockers (A62613)
72" JCT TILLER (A62613)
72" JCT TILLER...
Tool Box (A64127)
Tool Box (A64127)
