Firewood Questions
/ Firewood Questions #1
40_acre_mule
South Mississippi
Kubota L4701
#1 Do y'all cover your firewood after it is split? Tarp, shed, what?
#2 How far do y'all stack the wood from your house?
#3 How long do you let it sit before using it in the fireplace?
/ Firewood Questions #2
No! my stacks are out under the fir trees around the house
I keep 2 cords 25' of the house that is under cover(shed roof) that is for use this year! I'll fill it 3 times during the season. The rest is 50' to 100' from the house depending which tree it's under.
what I'll be using this fall/winter I cut 2 summers ago. so it's almost 1 1/2 to 2 years split drying before use!
/ Firewood Questions #3
I pile mine on pallets in rows about 20 feet long. The piling method I use allows me to have two rows about 4 feet high and I build a pitched roof with pieces of fire wood along the top to shed the rain. Just before snow I cover the top of the piles with plastic.
I have a space located about 100 feet from the house where I can stage at least 20 full cords of wood in piles. That is a little over two years supply so I can have wood that has been "seasoned" for two years. I burn mostly hardwood. During the winter I pile wood on the back porch which holds about 1 1/2 cord the wood stove is right inside the door in a "mud room".
Randy
/ Firewood Questions #4
Yes, I keep it covered. Either in a shed about 1000' from the house, or in racks I made that go in the barn (400') away.
I prefer to season the wood at least 18 months. It really burns better. However, we have had really wet weather the last two years and I'm behind...way behind.:(
Ken
/ Firewood Questions #5
I used to stack nice neat piles. Now it's in a heap at the edge of the woods. I throw a plastic tarp more or less over the pile and put a few logs on top to hold it down. In the winter, I put a nicer looking rack by the basement walk out door to hold a half face cord or so. I like to season for at least 18 months after splitting but I use mostly wood that's been down for a year or more before I cut it, so I don't worry too much.
/ Firewood Questions #6
I keep the wood under a roof in an open shed and cut it at least one year in advance. That is, I have this coming winter's wood in one side of the shed and am trying to get the side I emptied last winter filled before July. I often don't get the empty bin filled until late fall. I also split the wood fairly small so it is very dry by time it is burnt.
I don't have a fireplace but heat entirely with a wood furnace (has electric furnace backup) and use about 2.5 full cords (pine, fir, birch) per year. The furnace has a thermostat-controlled air supply which helps regulate the burning. If I burned in an open fireplace I would likely need to change a bit so it did not burn too quickly.
Burning dry wood helps avoid smoke and creosote problems.
/ Firewood Questions #7
Seasoning your wood at least two years is very important. You will be amazed at how much better heat you get from 2 year wood. Also know that seasoned two years means that it has been cut to length and split that long. Some people think that if the wood has been down several years that it is seasoned. Nothing could be further from the true. It makes little difference how long the tree has been down. The seasoning process does not start until the wood is cut to expose the ends. Most logs will rot through laying on the ground before they give up the moisture that seasoning removes.
I pile my wood about a quarter of a mile from the house because I stack it on the top of a hill in the back of our property where it can get the most sunshine and drying breezes. In the fall I start to 'stage' it stacking about half a cord against the garage where the outdoor wood furnace is and the rest near my pole barn. If I cover the wood out back it is only over the top leaving the sides open so the log ends are exposed to the drying breezes.
JN
/ Firewood Questions #8
Some woods dry faster than others, just as different varieties have different BTU ratings.
But I have another question: What month(s) do you fell? Before the sap is up? Summertime, in full leaf? Dead of winter? Whenever you get A Round Tuit?
I have a lot of standing dead locust trees, so I fall into the latter camp.:D
/ Firewood Questions #9
Personally I "Fell in the Fall and Split in the Spring" I burn mostly Oak and the six months of wintering drives the sap out enough to make splitting easier.
/ Firewood Questions #10
my pile is 50' or so from the house. i cover the split part with a plastic tarp. the split part is about enough for a week depending on the weather. i get firewood as i need it with plenty of standing dead locust around.
/ Firewood Questions #11
What species of wood are you asking about?
The wood will dry faster and stay dryer if there is a cover over the top (not the sides).
Stacking wood against the house is asking for bugs to get in the house and will create a place for high moisture leading to mold.
How long it sits? Depends on the species, how small it is split, how long the length is, what the drying conditions are, and how dry you want the wood to use in your fireplace.
Some people are satisfied to burn wood that isn't dry. So it all depends. ;)
Wow, thanks for all the replies. I knew y'all would come through.
I follow the Round Tuit schedule of cutting.
I am mostly cutting red oak and live oak. I have many dozens of trees that were badly damaged by Hurricane Katrina. I uproot them first to avoid leaving a stump, then take the chainsaw to them.
I cut in 18 inch lengths.
I live in south Mississippi about 8 miles from the beach. We don't need no stinking wood fired heat. All our burning will just be for looking at.
Surprise, surprise! Y'all have made me think of more questions.
How long do you wait after cutting to length before you split?
How big is a cord?
/ Firewood Questions #13
At the cabin where wood is the primary heat source, the seasoned split wood is stacked under the balcony ready for use... the walls and balcony are made of concrete and concrete block with stucco... nothing for the bugs to get into.
Two years season time with the stacks out in the forest with roofing over the stack...
At home, in California... wood seems to season much faster... cut and split in January and ready for use in November... here it is common for go many months in the summer without a drop of rain.
Some people have no concept of the value of seasoning... I had some fresh split and stacked wood at a rental home... the tenant's wife asked if they could use it and I gave the OK for next winter... this was in February.
I went back a few weeks later and all the wood was gone and then I found out they had burned it all in my Catalytic Buck Stove... The wife said her husband had a real hard time getting the fire going, but once he got it going, he never let the fire go out... sizzle, steam and all.
/ Firewood Questions #14
I stack mine on pallets and wrap them in plastic wrap. It's kind of like a giant roll of Reynolds wrap. I usually cover everything and then poke a "breather" hole in the top. This way the air can get under it and the hole let's moisture escape.
The clear plastic let's the sun beat on it good. It really draws the moisture out quickly. When it's hot the plastic is always covered in condensation. If I do it this way a year is plenty of time for seasoning
/ Firewood Questions #15
In general wood should be split and stacked for 10-12 mths to get to around the 20% moisture level. This will depend on several factors, the type of wood, the method of stacking, the amount of wind & sun the wood receives and the size/length of the split wood. If you can have it split and stacked for another 6-12 mths that should get you down to the 15% moisture range. I usually only make the 10-12 mth range and my masonry heater heats our entire house all winter up here in Ontario, never have to turn on the furnace. Like others, I stack mine on pallets and I place a cover over top - this is a debatable practice. Some people do, some don't. I have been in both camps and this year decided to cover the top. It will all be moved to a shed in September to keep the snow off it and to further dry it out.
/ Firewood Questions #16
Hi,
A cord is 8' x 4' x 4'. 4' is 48", so three 16" logs deep.
I have only taken this seriously since Christmas, when I installed my new wood stove and got rid of the old insert.
I split as soon as possible after I cut because the splitting will make it dry faster. If you are hand splitting, you may need to do it when the splitting is easiest...a different issue.
I stack mine on pallets is a criss-cross pattern. Since I see moisture press out the top during the splitting, I don't cover for around 6 mos.
When I cover, a good reasonable thing to cover with (for me) is tar paper. Tar paper is inexpensive, black, so it should be hot in the summer, and it will likely last until burning time, at which point I will dispose of the paper by burning it too.
Often, if available, a good thing to weight the paper with is old shingles. But, pieces of wood will do too.
If the wood is stacked in a long stack, the tar paper will stick out a good bit, and I have found it keeps my entire stack dry top to bottom.
My pallets keep all the wood off the ground, but I also use a more typical stack too..and I do this with storage racks so the wood is off the ground.
You want your wood to have less than 20% moisture at burning because of creosote prevention, and to get max heat. Since you don't need the heat, you want to avoid the creosote.
/ Firewood Questions #17
This method would be the worst one for drying wood. It would be the best method for keeping moisture in the wood and for creating the perfect conditions for mold and mildew to rot the wood. If it works for YesDeere, then that is fine. But can't be a good method for anyone to follow if drying or seasoning firewood is the intent.
A cord is 128 cu. ft. of volume. (i.e. 4'x4'x8')
/ Firewood Questions #18
We also bought some of that orange plastic temporary fencing material they use at construction sites along the road. My criss-cross pallets are unstable to move, so I go around the pallet with that material, and apply bungies, move the pallet where I want, and remove and reuse the orange material for the next move.
It is not a good idea to cover the sides of a stack...just the top. Air should free flow through the stack from all sides, and the bottom of the stack should not touch the ground if you can avoid it. Sometimes, I use cedar logs along the bottom to keep the other wood out of the muck, dirt, and moisture. The cedar will last a long time. But any small tree can do it same thing, but just won't last as long.
small trees or cedar look like this
gap
then I stack the wood on like this
|||||||||||||||||||||||| but the wood is long enough to cross the gap, and lay on the rails, obviously.
My pallet pattern looks like this
then second layer
I try to leave about 1/2 inch between all side by side wood, so in the end, wood doesn't touch wood beside it, but does touch would above and below, but only at a point (or patch).
All odd shaped pieces are put on last to form a small dome, and the tarpaper patch will be applied over the dome. In another two weeks or so (since it is starting to heat up here, it will be time to apply my tar paper.
Here is a picture of a conventional stack..it is too close to the house for dirt, but on concrete, the termites will have difficulty finding water. It is 3-4 inches off the retaining wall. The barrel in the background is for burning some punky wood my brother wanted to get rid of. Some of that wood had termites too, and I need to get it burned pretty quick, thus the barrel. I put strips under the treated boards, and angled the strips. This pile will be the first burned this winter, since it is quite old. It also came from my brother, but was on a pallet wrapped with woven wire fence. It sat outdoors uncovered for several years, and was packed quite tightly on the pallet. Now, I do my own wood, so the wood for winter after next will be fresh dry red oak, that me and my buddy cut to 15" lengths and split with our new splitter we share.
/ Firewood Questions #19
I have a wood shed specifically made for the wood I need for One year usually about 5 cords this year I burnt close to seven. I have another shed that I fill with next years wood. I burn mostly larch, or fir. As soon as the roads open up I will be getting the wood for 2 years from now. I have a 14 ft dump trailer with sides on it and get about 2 cords stacked on it. I open the back doors take out the last 4 ft, then close the doors and lift the box, the top of the doors come about mid thigh and self fill easy as heck to stack.
I burn 2 ft wood in a wood thermostatically controlled furnace.
I have a rack with 4 shelves in the basement about 6 ft long. Two days supply on the coldest day.
I have a two wheel cart with an extension base on it, and have a large plastic garbage can, tied on it, to bring in the wood.
Works for me!
Holy Cow!
I had no idea there was so much science to firewood.
We have a little firepit off the back porch where we intend to burn a few logs now and then.
Plus, we have an indoor fireplace, but we haven't decided if we'll burn wood, or use gas with some fake logs.
But, most of the wood will go to my daughter. She has a house with a fireplace that she uses to supplement her furnace.
Thanks y'all.
Mule
2014 Kobelco SK210LC Hydraulic Excavator (A64553)
2014 Kobelco...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
2020 Komatsu PC210LC Hydraulic Excavator (A64553)
2020 Komatsu...
2011 Chevrolet Camaro Coupe (A64194)
2011 Chevrolet...
227 (A64278)
227 (A64278)
