big tex opinions
/ big tex opinions #1
rwells
ottawa ont
kubota u45
Hi im looking at purchasing a big tex trailer 22gn 20+5 but dont know anything about these trailers
/ big tex opinions #2
I've only owned one of the smallest Big Tex trailers (primarily to haul a little ZTR mower), but of course I see plenty of them. They aren't cheap, but from what i've seen they're very good trailers.
/ big tex opinions #3
My daughter lives very near to where they are built. I've checked them out several times. I'd buy one in a heart beat.
/ big tex opinions #4
I have a Big Tex gooseneck to trailer my M 6800. I am very happy with mine. Is very well made. No problems with it at all. Is this like the one you are looking at?
/ big tex opinions
Im looking at 20+5 it has double duallys.
/ big tex opinions #7
I've owned two Big Tex trailers, a utility and a car hauler. Never had any problems but I wasn't that happy with the way the wires were run on the car hauler. I would buy another however.
/ big tex opinions #8
I dont have a Big Tex, I have looked at them, they are built good and one thing I have noticed on them is the ramp operates smooth and effortlessly without hurting yourself, alot of others are spring assist, but are sloppy and hard to operate. Next time you look at one fold the ramp up and down and you will really like the way they operate.
/ big tex opinions #9
Got a lightweight 4x8. No complaints, except the wires were supported by washers tacked to the frame.
Bruce
/ big tex opinions #10
I have a GP12 20' gooseneck. No complaints, any other trailer I buy will most likely be a Big Tex.
/ big tex opinions #11
I wonder about the "C" channel gooseneck construction? I never heard of any issues nor have I ever owned one but my preference is "I" beam construction.
/ big tex opinions #12
You can get either one, I had that choice on mind, and I went with the 12" I-beam neck. All most all the trailer makers offer that. Keep in mind there is 14lb, 19lb and 22lb 12" I-beam, most wont say, but the19lb is the most common used.
/ big tex opinions
the frame and neck are 12'' 16lb I beam.
/ big tex opinions #14
We have had a 12PI since '03. Good solid trailer, tracks well. Great quality.:thumbsup: Can't go wrong with a Big Tex.
/ big tex opinions #15
I have owned a smaller Big Tex landscape trailer for a number of years. Structurally it has been fine and the paint still looks good after being stored outside for years. The weak point is withing. I have had to chase down electrcal problems and replace the lights with LED lights. Wiring is a problem with a lot of trailers I looked at.
/ big tex opinions #16
I'm also looking now at buying this class of gooseneck (20'+5' dual tandem @ 22.5K lbs GVWR). Big Tex and PJ are on my consideration list. Big Tex dealers appear to offer the best pricing (< $8K). Others of impressively good structural design found are Elite (Spiro, OK) and Mirage (Nampa, ID). Good used goosenecks are priced $5-7K which is hard for me to justify versus buying new.
/ big tex opinions #17
Oh okay, I did not know that. Thanks
/ big tex opinions #18
I just sold a 2008 Big Tex 7K car hauler (that I bought brand new) to buy a Load Trail or PJ. What I noticed with mine was that the company did not primer or paint the iron below the decking. They merely placed the pine boards over the metal and painted only the metal that was visible. Another thing that I noticed was that they ran the wiriing (unprotected) through washers welded to the frame. I was afraid they would wear and short out. I also noticed that the deck boards were not of the same quality as those used on PJ's or Load Trails... the Big Tex boards were very warped. Check photos of the decking shown on dealer web sites and you'll see what I'm talking about.
Other than the quality control issues, I had no problems with it. I'd take a close look and compare the obvious quality control issues on trailers you're concidering.
/ big tex opinions #19
I own a Big Tex 70 CH. Had to rewire the harness. The factory had long shiners hanging out of the butt connectors. Poor wiring. The wires in rear were placed through welded washers which could chafe. The four foot ramps on mine needed auxilliary wooden ramps added to load tractor and ballast box. JIM
/ big tex opinions
Thanks for your replys everybody I just purchased my big tex 22gn yesterday
Im picking it up on the way home tomorrow.
2025 CATERPILLAR 255 SKID STEER (A65056)
2025 CATERPILLAR...
2018 CASE 650M LGP CRAWLER DOZER (A65056)
2018 CASE 650M LGP...
2007 CAT 140H MOTOR GRADER (A67714)
2007 CAT 140H...
JOHN DEERE 4052M TRACTOR (A65057)
JOHN DEERE 4052M...
213090 (A64276)
213090 (A64276)
2010 Rhodes AS3575-3 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A66736)
2010 Rhodes...
