power stain sprayer's
/ power stain sprayer's
Thanks Bird,.. well I wont keep beting a dead horse but thanks for the information. I will buy one soon I was planning on a wagner till i started reading the reviews .They sound like they may not be the best choice and maybe one of these will be. Thanks again keep yer powder dry
/ power stain sprayer's #23
That's fine, Jeff. But keep in mind that the Wagner is "good", too; just noisy and a lot of vibration.
/ power stain sprayer's #24
I don't think you will ever get away from the brush if you want good spread and penetration of the stain. I suggest renting or buying a good airless sprayer that has a hose or intake that sits directly inside the bucket. I have a Wagner Paint Crew machine that works okay for stain, but it would be much nicer to have a higher level machine. The Paint Crew costs about $200 new.
I suggest buying a horsehair or other fine bristle radiator brush. Even a horsehair pushbroom works well for spreading stain after you spray it on. The brush just helps get the stain down into the grain of the wood. The big push broom makes brushing quick and easy. I even use one when I stain the siding on my house. You aren't looking for a fine paint finish, just working the stain down into the grain of the wood.
X2 off ebay for $135. and change
/ power stain sprayer's #25
When I stained my deck, I remember reading somewhere, maybe on the label of the stain, that spraying wasn't the recommended application. As I recall, they recommended a brush or roller as the best way to get more even coverage.
I sprayed it with my paint gun and air compressor anyway.
How much fence do you have to stain anyway?
It is 6' by 150' i have brushed it once using a pump sprayer and brush. Just dont want to brush it again.
/ power stain sprayer's #28
Yep, for more even coverage, to prevent runs, etc. some of the labels recommend a brush, too, even if you are spraying. And of course lots of folks (who probably know more than I) think a brush pushes paint and/or stains into the grain better than spraying. But it just always seemed to me that a finely atomized spray would get into cracks and crevices that a brush couldn't get to.
Yea me too,I did read of a guy that brushed with a push broom that sound better if you have to do it.
/ power stain sprayer's #30
The sprayer seemed to force it into the wood, but I had some nonuniform spots. However, the job was done more quickly than I could have done it by hand.
The owner's manual for the Wagner "Optimus Plus" sprayer says "the stain tip has a specially designed opening for use with thin materials such as thin stains, sealers and waterproofers....If you did not receive a stain tip...the tip can be purchased at your local retailer."
My impression is you'd have to buy the stain tip, too. That still doesn't answer your original question of how it well it would spray stain. Wagner's technical services telephone no. is 800-328-8251. You might call them and ask which product they'd recommend for the job to see what they say.
/ power stain sprayer's #31
I was thinking he was referring to the hiding stain almost like pancake syrup (read thick) that is what I did my deck with.
/ power stain sprayer's #32
I guess I have confused everyone so I will sum up.
I stained my deck with a HVLP paint sprayer and a compressor. The stain instructions said to brush it or roll it, however. I had a few spots where I got too much material and it ran. But overall, it was much faster than brushing or rolling.
Later, I bought the Wagner Power Painter Plus with the optimus dual tip to spray some metal porch railings with paint. I had trouble with it spraying globs of paint.
Since the OP asked about using one of these to spray stain, I also looked in my owner's manual, and it seems to say he would have to buy a stain tip to spray with.
If the OP were next door, I'd give him this sprayer to get it out of my garage and ask him please not bring it back.
2016 John Deer 5075E (A60462)
2016 John Deer...
2012 Infiniti QX56 (A61574)
2012 Infiniti QX56...
7' ROTARY MOWER (A63291)
7' ROTARY MOWER...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
2011 Ford F-450 Crew Cab Mason Dump Truck (A61573)
2011 Ford F-450...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
