Witch Woods backhoe should I go with....
/ Witch Woods backhoe should I go with.... #1
Bswope
South Central PA
Kubota Grand L3540
Hi fellas, I might be buying a backhoe for my tractor and im lookin at the Woods line. I went to my local dealer today and asked witch one I should go with and he said either the BH70-X or the BH80-X.
Now came the prices.....
BH70-X came to $7200 installed
BH80-X came to $8400 installed
They had a BH80 there but it was loaded on a truck and sent to their other dealership right before I pulled in so all they had was a BH70 there and it looked kinda small.
Has anyone had either of these backhoe's on a tractor similar to mine in my sig, Im leaning towards the BH80 if my tractor can handle it.
Thanks guys,
Buddy
/ Witch Woods backhoe should I go with.... #2
On your tractor, I'd go with the 80X. I have one on My B3030, and thought it's alot of hoe for my tractor..... it'd be appropriate for your GL. IMO, a 70X is smallish for your tractor.
/ Witch Woods backhoe should I go with.... #3
I think the Grand L's will easily handle a BH90 Woods hoe, unless there is something about your cab setup that prevents using that particular model. Going with a hoe that reaches farther and deeper has offered advantages for most of the backhoe projects I've worked on since it cuts down how often you need to reposition the machine. I'd reckon that would also be particularly useful with your cab setup since you'll have to move to the driver's seat and back each time you move it. I'm sure the BH80 would work fine, but you may save yourself some climbing around and maybe be more productive with the larger model.
/ Witch Woods backhoe should I go with.... #4
Grandad is correct , your Grand L will handle the BH90. If you go to Kubota .com build that is just one model that's offered for your tractor. I had the BH76 on my B3200 and the Grand L is much larger and heaver tractor.
DevilDog
WOW..... The BH90? Hmm, my tractor PTO hp is 28 and looking at the Woods ratings it calls for a minimum 30 PTO HP, Im not sure id want to go too big and be under powered for the hoe. I know its only its only 2hp but my tractor is on the lower end of the rated PTO power for the BH90 and I dont want to have all that hoe and not be able to use it, as in having a week feeling hoe.
There is a pretty good difference in reach between the two so that would be nice to have the extra reach so I didnt have to move as much but I can also leave the tractor in " N " and drag it around with the hoe. I work construction and have a fair amount of experience operating backhoes and excavators and I like to push and pull myself around with the hoe "when I can".
I know my tractor isnt like our equipment at work and have to be very careful but Im thinkin the BH80 might be a better fit for my tractor since it has plenty PTO hp for the BH80.
Hmm Ive got some thinking to do now!!!:laughing:
Anyone ever run a BH90 on a smaller Grand L....?
/ Witch Woods backhoe should I go with.... #7
I have a BH80X on a B3030 as well it it works great. If your tractor will handle the BH90 than I'd go with that. I have the mech thumb and wish I'd have gone with the hydraulic. I also wouldn't bother with the PTO pump, I'd have your tractor plumbed for rear hydraulic remotes.
So I could run the hoe off of a set of rear remotes?
/ Witch Woods backhoe should I go with.... #9
Mine has a set of hydraulic hoses running from the loader control to the back of the tractor. The BH hoses hook right up. I bought mine last yr and the dealer had a special buy on the BH80X (prior yr models), it was $7500 for everything installed.
/ Witch Woods backhoe should I go with.... #10
If you use the "Search" function, it looks to me like you'll be able to find some threads about a Woods BH90 (or its predecessor, the B9000) on the smaller Grand L's. The 3540 has 8.3gpm available for the implements if you use remote hydraulics instead of a separate pto pump. A Woods dealer should be able to advise how that might work with their BH90 (or maybe a phone call to Woods). The pump would eliminate any flow limitations, of course, but costs additional and is a minor hassle when attaching/detaching the BH.
Just going on what has happened to me, backhoe performance is a function of hydraulic flow more than pto horsepower, and the backhoe seems to be just as happy with moderate rpm as running at full throttle. That's in contrast to the operator - me - who needs to back off the rpm since too much flow makes everything pretty quick and jerky on my BH... a reflection of the operator, no doubt! :D Note I have a Kubota hoe, not a Woods. So your 28 pto hp might be marginal on paper but in practice may be fine. Maybe someone else can give a better comment.
Size and weight wise, I think your 3540 should handle the BH90 OK.
Ive searched..... trust me!:laughing:
/ Witch Woods backhoe should I go with.... #12
You only need a simple power beyond loop to the rear to power the hoe. I'd say about $200. You can do the install yourself if'n you want.
/ Witch Woods backhoe should I go with.... #13
Here are some threads I pulled up that mention Woods and/or BH90 from the Kubota Buying or Owning sections:
http://www.tractorbynet.com/forums/...0-plus-woods-bh9000.html?highlight=woods+bh90
http://www.tractorbynet.com/forums/...3130-loader-backhoe.html?highlight=woods+bh90
http://www.tractorbynet.com/forums/...2-bh90-woods-9000-a.html?highlight=woods+bh90
http://www.tractorbynet.com/forums/kubota-buying-pricing/124006-l3240-l3540.html?highlight=3540+bh90
http://www.tractorbynet.com/forums/...9-3430hst-w-723-bh90.html?highlight=3430+bh90
http://www.tractorbynet.com/forums/...khoe-loader-question.html?highlight=3430+bh90
http://www.tractorbynet.com/forums/...3-l3430-capabilities.html?highlight=3430+bh90
http://www.tractorbynet.com/forums/kubota-buying-pricing/29998-3130-3140-a.html?highlight=3430+bh90
http://www.tractorbynet.com/forums/...97-looking-tractors.html?highlight=woods+bh90
http://www.tractorbynet.com/forums/...6-l3240-price-check.html?highlight=woods+bh90
It gets confusing because both Kubota and Woods call their 9ft hoes "BH90", (although Kubota jumped up to a "BH92" recently). Although the Woods BH90 is a newer design than the Kubota one, they are broadly similar in size and general capabilities, and if one works on a particular tractor, the other one would likely also work similarly if installed on the same tractor. There seem to be a fair number of 3130, 3430, 3240 and 3540 tractors with one or the other BH90. There were more threads than this, but these were ones that seemed to match pretty directly to what you're considering.
My point was not to sell you on this idea, but to help you find others who put 9 ft BH's on their 30-35 hp Grand L's. Maybe some of those posters are still around or might respond if contacted. Please go with their input or that of someone who actually has comparable equipment, and not mine. I hope this helps a bit, and wish you all good luck with your decision.
^^^^ thanks man!! :thumbsup:
Very good info also!
I just bought the BH92 Kabuta BH and I also have the L3540, can I ask why you are not considering the Kubota BH?
Beings that im a heavy equipment operator IMHO the Woods backhoes are built VERY similar to the hoe's on CAT and John Deere equipment, they look to be built VERY STRONG and to me look very much more stout than the Kubota BH's.
Not saying that the Kubota BH's are not built tough cause im certain they are, I just feel the Woods are the better buy.
/ Witch Woods backhoe should I go with.... #17
Are you comparing the Kubota 90 or the 92? As my dealer had both the woods and the Kubota 92 (new design) in stock and the Kubota looked more rugged to me. It just seemed to make sense to put the Kubota on a Kubota. I only mention this to you to make sure you are looking at all your options. The other reason I went with Kubota was that I could put it on my 0%lease.
Well to be honest, my local dealer only had one Kubota BH there to look at and it was the same size as the Woods BH70-X, curved boom and all so thats kinda what I was going off of and figured there would be any difference in the bigger BH's, and Ill be honest I havent seen the Kubota 92's... Maybe its something I need to look into......:thumbsup:
My local dealer mostly sells the Woods line of BH's and actually reccamend them.:confused2:
/ Witch Woods backhoe should I go with.... #19
I am sure either BH would be great, I worked with mine all day yesterday for the first time and it was great, I just have the mechanical thumb, I could not justify the hydrulic thumb as when it comes right down to it I should not have justified the whole tractor. I am far from an expert on these backhoes it would be great to hear from anyone else that may have compared both these units. My dealer who has become a pretty good friend over the years pushed me towards the 92 after comparing the specs. To be honest I just took his advice and did not compare the specs personally, maybe I should have....I think the Kubota was a little more expensive. I did not price things out separtely.
/ Witch Woods backhoe should I go with.... #20
I'd agree with what BillHall said. The Kubota 9ft. hoes have always been very strongly built and good performing hoes. Until recently at least, they were better integrated into the tractor than others (my opinion)... heavier subframe and didn't hang out so far off the back of the tractor since they were specifically designed for the Kubota and not a generic hoe adapted to particular tractors. I think the newer hoes from Woods and others have improved quite a bit on those things and are very much equivalent to the factory BH90 ... actually in some respects better.
It's a mistake to dismiss the Kubota product out of hand, though. Remember, Kubota not only makes the small hoes like you saw, they also make commercial mini-ex's and TLB's, and I don't think anyone would say those BH's are wimpy. The backhoe market for the large frame CUT's like the Grand L's is very competitive. The manufacturers are constantly trying to out-do the others, which is good for us customers :). Kubota's BH92 is the newest one in the market now, and probably one-ups the competition in a few areas... at the moment. You really would not get a bad product from either Woods or Kubota or several other brands.
