300cx Repair ??
/ 300cx Repair ?? #1
foggy1111
Elite Member
Nisswa, MN
Kubota L 3560 HSTC, 805 Loader
I broke the left casting on my loader to which the bucket attaches. I have one on order from the dealer.....so I thought I would get a head-start on pulling off the broken part so I could bring it along to the welding shop to show how to fix things.....in order to get my grapple fixed up correctly (which is the problem child here).
There are two fasteners holding my broken cast part - a "bolt" (threaded pin) at the top with a nut (no problem)......and a tubuular affair at the bottom with two cross pins and cotter keys. It looks harmless enought....but, this "tube" at the bottom pivot is giving me troubles. And.......I dont understand how to remove it.
I pulled the two cotter keys and pins from each side and tried to drive it out from either end. No dice. The tube seems to rotate but either end seems independant of the center tube, when I rotate the tube? :confused: So far nothing is moving and I dont get the disasembly here. I looked at JD parts....it looks straight forward......but alas, I'm missing something. Anyone had one of these apart? Advice?
/ 300cx Repair ?? #2
Cant help you on removing the shoes, but I knew I shoulda kept the "shoes" that came with mine...My dealer gave me the factory JD Shoes but I told em to chuck em in the scrap metal bin...For the cost of shipping I woulda gave you mine (if i had em).
But hey thats an idea..mebbe someone else out there who's upgraded to the SS/QA has the factory shoes they'd part with for cheap?
/ 300cx Repair ?? #3
How many cross pins did you have to pull? Two or Four? On John Deere parts it appears to be a one piece bar, yet you say it rotates independent of the ends.
I wonder if its broken? Have you kept it greased?
On my JD 640 loader there are four cross pins with cotter pins. The cross bar is solid as are the pivot pins. I am thinking on mine the pivot pins are separate since they are wear items.
/ 300cx Repair ??
I pulled two 3/8" cross-pins....one on each side. Yep...it seems like it should just be a one-piece bar that pushes out from either side...and that is why it is unpainted :confused:. But it doesnt budge laterally when I tried to drive it with a block of wood and a hammer. I can rotate it somewhat, but when I hold the end it does not turn with the center. I only have 250 hours on this machine....and yep, I keep it well greased.
In the pic below, its the shiney tube that connects both sides that is giving me the problem. It sure doesnt appear to be that complicated and I cant find any other fasteners on the machine, or when looking in JD parts.....:confused2:
I sense I am going to have one of those "ahah" moments coming up....followed by a "duh".;) I guess I will ask the JD service manager how to disassemble.
/ 300cx Repair ?? #5
I wonder if the mounting bracket needs to be removed so they slide out from the inside and not pushed out. but that leads to the question why they are pinned on the inside of the brackets. JD parts only shows the 2 pins but nothing about how its removed.
/ 300cx Repair ?? #6
I changed mine, but don't recall any issues. Maybe just pull the carrier off the bar, don't try to push the bar thru the carrier.
That bar is just to keep the carriers in sync with each other. Properly spaced and in the same roll position.
My 300 came with an earlier style carrier that was prone to breakage, even though they never broke the dealer gave me 2 new ones. so I did a little experimenting with the old ones. made a Doctor Seuss contraption :eek:
JB
/ 300cx Repair ?? #7
I think you are right, the pins are just to maintain the proper spacing between the carriers, so it wouldn't matter if they were inboard or outboard.
JB
/ 300cx Repair ??
That pic that JD4310 posted is pretty discriptive of the situation. Also the parts explosion. With The loaders mast going between the flanges on this casting there has to be another fastener means....or that shaft has gotta slide. :confused:
Dazed and confused and foggy too.
/ 300cx Repair ?? #9
Does it possibly have a shoulder or collar that holds it captive between the two loader arms? If so maybe #15 in the illustration above has to be removed first. I cannot tell by the picture or exploded diagram.
Just a thought.
edit: after carefully studying the diagram the shaft itself appears to have a shoulder on each outer side. I am guessing the #15 must come off.
/ 300cx Repair ??
Just a thought.
I'm not by the tractor now.....but I think you gotta be right. The exploded view really doesnt show a part tho.....I may get over by the tractor today for another look. My replacement part gets to the dealer tommorow...so I will ask the service manager if I cannot figure it out.
I had hoped to take this part to the welding shop so he could use the broken piece to size up my grapple repairs. Some stuff will just have to wait. ;)
Thanks for the help.
/ 300cx Repair ?? #11
So are you going to share the details of what exactly happened? It's a common tractor and grapple so maybe your bad experience can save someone else the headache your having. FYI those loader parts are often for sale on ebay. Maybe you can save some $$$.
Matt
/ 300cx Repair ??
I did write about this misshap on the Kioti page and I think on the JD page. Here's the scoop.
I bought a Gator (formerly Markham) 48" grapple last fall and had only used it for light duty work until Tuesday....when I had lots of trees, brush and stumps to move. After several hours of pretty hard work.....the top saddles on the Gator grapple bent under a load....thus un-coupling on the top left side. It must have gone unoticed or I had lots of load on it when this happened....as the lower pin then became stretched, then musta bent and the hole (for the retainer pin) is elongated and finally went missing. Under load....the now, bent and elongated pin musta pushed hard enough on the JD casting to break it.....at which time I noticed the problem. BOTH saddles are streched and bent. :mad: grrrr.
When this happened I was in the middle of a thick, nasty pine teee / stump tangle and I was working things pretty hard. Abusive....maybe.....but then grapples get a hard workout. I often tried to pick things up that were stuck down or too heavy. Thats just the way it is.
If you have one of these grapples and have a JD mount.....make certain that you have a gusset (like John Deere puts on there buckets) welded on. With hard use you are LIKELY to have problems with the Gator / John Deere mounting set up the way Gator supplies it......IMO. $2 worth of steel and 2 minutes worth of welding would have prevented this issue for me. :mad: Why izzit a person has to re-engineer some stuff? :confused2:
I went back to the tractor today.....and while I see that the pins are independant of the "spreader bar".....I cannot understand how to get them free from same. I can rotate them a bit....but they will not work free. I am missing something here. :confused:
/ 300cx Repair ?? #13
Froggy that sucks, I wish Millonzi was still around. They were kind of the pioneers of these light duty, cut specific grapples. The took great care to double up the saddles similar to JD's design. I hope you informed Gator about this so they fix the issue. There's no way that was your fault.
Matt
/ 300cx Repair ?? #14
I'm gonna go out and look at mine tonight, this is bothering me.
I said I had no issues changing mine, but now I remember I didn't do it, my laborer did it one morning, while I was probably on TBN :eek:
He didn't say it was anything special though, so you must be missing something simple.
JB
/ 300cx Repair ?? #15
That really looks like a one piece bar holding the two carriers to the loader mast. The two cross pins hold it in and keep the carriers in sinc. They must have put the pins inboard so they would not be thru the internal grease passage. I'll bet you have wear on the bar that formed enough of a shoulder it's hanging up the bar so it wont slide out.
Any sign the bar is bent? How did you determine the bar spins and the ends do not?
/ 300cx Repair ?? #16
JB
That would be so cool to use with a top link...:licking:
/ 300cx Repair ?? #17
I have a HTL now, but there is not enough travel for it to really be effective with the loader bucket, it's more of a novelty.
It does work great for the pallet forks, and the big bucket makes for plenty of trunk space :)
JB
/ 300cx Repair ??
I put a vice-grip on the center bar....and one on the end that protrudes slightly just outside the loader mast(s). I can work each in oposite directions-just a bit. The bar does not appear to be bent (but I sure am going to watch this bar better in the future - it is very vulnerable).
I gotta assume that these end pins should just pull out of the loader mast and "shoes".....but I dont know how I am going to get 'em out. The parts "explosion" does not show a seperate pin (???). Your bet that I have a shoulder formed may be a good bet. There is very little to grasp ahold of here....and no way to drive the pin, nor anything to pull on. Seems like an odd application....especially for Deere. :confused:
/ 300cx Repair ?? #19
Well I went out to my shed, turned the lights on and puffed on a cigar while daydreaming about a few things, when I came back in I realized I forgot to look at mine :confused2:
I will ask the guy tomorrow for sure how he removed them.
JB.
/ 300cx Repair ?? #20
I think I would spray a good penetrating oil where the bar goes into both shoes. Rotate the bar a few turns to loosen it up, then get a brass rod of smaller diameter than the bar and a BIG hammer and pound it thru the shoe.
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
ALLMAND MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
1 PALLET OF HYDRAULIC HOSES (A66091)
1 PALLET OF...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
