24T pickup issues
/ 24T pickup issues #1
sjbrunk0
Member
Edgerton, KS
JD 2040
This baler was on my property when I bought it 8 years ago, I'm now trying to get it running and am new to the hay making business.
I need to set the scene... I wanted to do a trial run so mowed a small patch just a week ago that has not been hayed in a while... but has been brushhogged down for the past couple of years. So there was almost as much old thatch as there was new hay. Maybe this is a factor?
The trouble I'm seeing is when I operate it, the hay starts tumbling in front of the pickup wires so instead of the hay lifting up on top, it just kinda rolls and accumulates, eventually leaving trails on either side of the pickup.
I wound up having to go over each windrow three times which was pretty rediculous.
Has anyone else ever seen anything like this?
Thanks in advance.
/ 24T pickup issues #2
I think you may need a new baler... From what I'm hearing from you right now this sounds pretty bad..
/ 24T pickup issues #3
sjbrunk0
Are the majority of pickup teeth in place? Are the compressor rods in place on the top of pickup strippers? What was the moisture content of the hay? How thick were the windrows? What ground speed were you trying to bale?
/ 24T pickup issues
Thanks to both of you for the responses!
Edward, I should clarify I own 40 acres and will just bale about 20 of those, so it's a pretty shoestring budget sort of thing... I'd like to fiddle with the baler I've got for a bit before I give up.
Jim, All of the teeth are present except one, I had to replace a bunch of those before I started as they were broken.
I'm not exactly sure what the stripper rods are but will look in my manual when I get home... I'm at my money-paying job now.
The hay was dry enough but not by a lot... it had sat without any windrow for a day and a half, and it got up to 90... and it was pretty sparse so not a very thick layer there.
I tried a variety of different speeds and it didn't seem to make much difference.
One thing I'm fighting is the pickup head bobs up and down a little bit, it seems like the teeth or similar are dragging inside the pickup head, and the torque from the drive sprocket winds up lifting up the head a little bit to overcome that.
I think that's probably part of the problem but there were times when I watched it rolling the hay and it was not bobbing.
Thanks,
Scott
/ 24T pickup issues #5
Over time the cam inside PU can get grooves that each tooth arm brg creates from acres of use that can cause resistance. Try loosening float spring a little. The compression rods curve out in front and then on top of pickup attachment. One problem with older sq balers was the teeth were spaced wider apart than on later model balers which contributed to hay pickup problems. Plus some later model JD balers had 6 rows of teeth instead of 4
/ 24T pickup issues
Ok, I do not have compressor rods on my baker. The manual lists those as an optional add-on and in the you tube videos I have been able to find I didn't see any with those so was hoping they were not necessary.
Are those little steel rollers that run around inside the pickup cam supposed to be greased, either along the surface of the cam or inside the roller? Please pardon my likely-wrong terminology.
/ 24T pickup issues #7
Are those little steel rollers that run around inside the pickup cam supposed to be greased, either along the surface of the cam or inside the roller? .
Compressor rods help hold down hay against the teeth. IMHO 14T had better compressor than 24T so you might retrofit those on you baler as more 14T's could be found as a donor than 24T's. If you own a rake you could try raking a bigger windrow to help in picking up hay.
No lubrication is required as they are sealed brgs inside cam.
/ 24T pickup issues
Ok, got it. Any tips on how to find used equipment in my area?
/ 24T pickup issues #9
I have good luck on Craigslist and YTmag classifieds. Both are free. Where do you live?
/ 24T pickup issues #10
Sounds like a gauge wheel on the pickup reel would be a good option. It would help the pickup head to follow the contour of the ground without driving the teeth into the turf or leaving them "scratching air" over a low spot.
Maybe that's part of the problem of having the head "bob up and down".
The pickup strippers are those yellow metal strips that are between the rows of teeth. If there's a number of the strippers missing - the hay can fall back down between the teeth onto the ground.
AKfish
/ 24T pickup issues
I am near Edgerton, Ks, Jim.
I've started watching Craigslist and will check out the other one too.
/ 24T pickup issues
AKFish,
Thanks, got it. The strippers are all intact and secure.
The bobbing I mentioned even occurs when it's stationary... something is binding up inside the pickup head when it is running, and the torque on the drive sprocket lifts the pickup head until it overcomes that friction, then it breaks free and the head drops back down. I need to find the source of the friction but it seems like there are about 100 places to look.
When I looked at some similar balers for sale online I didn't see compressor rods on any of them, are they normally required?
/ 24T pickup issues #13
I have a 24T baler and have seen what you descride when doing light windrows. What did you mow it down with ?
Balers like long stemmed plant material not short clippings.
Buy bales hay or straw and spread it out into windrows or hand toss it in to see how it works..
/ 24T pickup issues #14
Back to basics: Did you cut the hay with a brush hog or a sickle type mower? Hay length is an important factor in pickup operation. Too short and it won't get picked up. A brush hop mower will sometimes work for haying, but there needs to be a lot of hay. Did you rake it into a windrow? If not, you need a substantial amount of hay on the ground in order to have the pickup work.
The pickup tines should never touch the ground. That makes the tines stall and grab and then break free. Adjust the header height so that the tines ride no less that an inch above the ground. You should be able to make a ground riding gauge wheel to let the header float along with the ground level if you have hilly land. This was a factory option. The header should not be making a lot of noise. If it is, then the cam riding rollers may be frozen up or the tines are rubbing against the strippers, which can cause the choppy header operation.
/ 24T pickup issues
Thanks Buck, I was wondering if that might be the problem. I cut my test area really early so it was short. Also had a lot of old thatch in it so between those two it was more fluffy than stemmy. Also the windrows were very lite and a little too wide.
/ 24T pickup issues
Thanks, zz. I am just getting my #9 sickle bar working for the first time this year, field has been brushogged in the past so there is some thatch in there. I also did not fertilize this spring (kicking myself now) so the grass is pretty thin.
The thatch in the few test bales I did pick up does not smell so great. I wonder if I'm going to run into this "old nasty thatch" problem everywhere.
/ 24T pickup issues #17
The 24T chain drive on the pickup(if rusty & stiff) along with worn drive sprockets can cause chain to hang in the teeth of the sprockets creating the bobbing of the pickup up attachment.
/ 24T pickup issues #18
So i take it your baler did pick up enough material to cycle and create some bales? your crop should be at least knee high and cut with a sickle or disc cutter.
I took over a old bushhogged field for hay and it took a entire year to get it cleaned up for good grass hay. the first years hay wasnt too good with all the old thatch picked up.
/ 24T pickup issues
Thanks, Jim.
I did make about a dozen bales. The baler was picking up fine at times, and at other times the stuff started to roll and build up in front of it, leaving a couple of messy rows on either side of the baler. I think I'm gonna hope that with longer hay I won't have so much trouble with this. I made my boys run along with a hand rake and pull the mess into a single row, they said if they gotta do all 40 acres this way they will go on strike :)
Regarding the bobbing pick-up head, you may be onto something with the chain binding up. The drive chain was pretty frozen up when I started and I have not been able to fully loosen it up even after soaking in motor oil overnight, using lots of PB Blaster, cleaning the sides of the chain links with a wire wheel, etc.
Maybe that is the real cause and it will work itself out with time if I keep oil on it? A guy can always hope...
/ 24T pickup issues #20
Glad you're making progress on the baler. I would invest in a new chain. Back when I grew up on the farm, labor strikes by me weren't allowed by my father. Oh how times have changed. I hated walking up/down corn & cotton rows with a hoe but striking by me never crossed my lips.
250 gal Livestock Lick Tank (A66408)
250 gal Livestock...
John Deere Mini Excavator Wedge Lock Coupler (A65640)
John Deere Mini...
Bush Hog 176 3Pt Blade (A66408)
Bush Hog 176 3Pt...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
Lot 602 (A62613)
Lot 602 (A62613)
2019 GMC Terrain, AWD (A62679)
2019 GMC Terrain...
