I need a round baler!
/ I need a round baler! #61
Using sisal twine means you just feed the hay and stay in the comfort of a heated cab. Net-wrap on 4' wide round balers is not as popular in the center states like TN,KY,NC,VA,WV and other areas because this is the freeze/thaw region. Much of the hay is stored outside & net is frozen to the bale. When the net is frozen to the bale it is a mess to cut off & all this happens in the cold in the morning before work. The cow/calf producer often feeds in multiple places. The time saved on the front-end with net-wrap does not work on the backend.
So they can digest that stuff eh.
Makes sense to me.
D.
/ I need a round baler! #63
I have been looking at used round balers, and found one that I have questions about. It is a JD 458 standard, looks like new except for the pick up teeth are all bent, not in a straight line like they should be, yet it has both gauge wheels. Weird. The dealer says he will throw in new teeth but I have to put them on. Can anything else be damaged in the pickup that I cant see? Changing teeth is about like a SSB?
Also it is twine only, although it is electric with the monitor. I will have to store these bales outside until fed up and most everything I read says to go with net. Time isnt so much of a concern due to the quantity of bales I will be making per year but I dont want them all to spoil.
I can get it for half the price of a new 458 with net, so I am really tempted to pic this up soon, but if net is the way to go I will keep looking or break down and order one.
I have JD dealers close so that is what my search is concentrated around.
/ I need a round baler! #64
What kind of money are you looking at?
D.
/ I need a round baler! #65
Darin, the used 458 is around 13500.
/ I need a round baler! #66
you can get a brnad new New Holland Rollbelt 450 which is the equivalent of the Deere 458 for $17,500 with low rate financing for 4 or 5 years. THe New Holland comes with a rear bale ramp, gauge wheels, is auto wrap and has a monitor.
/ I need a round baler! #67
I didn't read every post here, but i didn't see anyone comment on your comment that you were looking at a Gehl.
I would avoid the Ford and Gehl round balers at this point since Gehl is out of the farm equip business and parts are already getting hard to find ( so my Gehl/ Ford owning friends tell me). The Vermeers are an excellent and economical choice as they have low hp requirements.
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
2R FALLING PLOW (A62131)
2R FALLING PLOW...
UNUSED REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED REMOTE...
CATERPILLAR 255 SKID STEER (A62129)
CATERPILLAR 255...
2004 Mack CL713 Tri-Axle Heavy Haul Truck, VIN # 1M1AD64Y04M001417 (A61165)
2004 Mack CL713...
UNUSED IRGC40 HIGH-END ELECTRIC MINI GOLF CART (A62131)
UNUSED IRGC40...
