Mowing Brush Hog check chains on slopes. C of G better/worse?
   / Brush Hog check chains on slopes. C of G better/worse? #21
As others note, chains are not "required", but I think you're missing some of the bonus of using them beyond help with weak hydraulics. With a flexible (toggle or chain) top link installed also, the check chains serve to do the following:
1) The chains provide a hard stop for adjusting the deck, better than any set point that the three point hydraulics can attain, even with a set point on the control lever. So, never any need to look back and find the right height. If additional temporary higher adjustement is required, one can always revert to the lever for a different (higher) setting.
2) If you install the chains so that the attachment point to the deck is NOT at the same point that the lower arms attach to the deck, there is no rigidity caused by a "triangle" established by the chains, lower arms and tractor frame. (See the picture found at the previous poster's TBN link) Thus, the geometry is free to move. The resulting shape has sometimes been refered to as a bow-tie quadrilateral or complex crossed-trapezoid. Obviously, a little difficult to describe, but the point is that the bow-tie shape is free to rock/flex/rotate.
3) The geometry results in the deck reacting to dips and rises of the front of the tractor in a reduced way vs what otherwise would occur using the lower link support.
4) The lower link control is set all the way down, but the links don't go to that point due to the limit of the chains. Because of this, there is some minimal weight put on the tail wheel as the lower links no longer provide any support except to "push" the deck away from the tractor. Although the chain provides most of the support, these also tend to try to pull the lower (below the 3-pt arm attach point) part of the deck toward the tractor, but this in turn is limited by the tail wheel(s) support.
5) The lower links are rigid. When using only these to support the deck (as advocated here), the deck seems to bounce more with every motion of the tractor. The chains seem to provide a bit of cushion.
I know this discussion has been had here at TBN before, and yet no one that has disagreed has tried the exact setup. If there still is doubt, and you don't want to bother to try, one might want to sketch the setup up or create a little cardboard, stick or other form of mock-up before shooting down the setup further. Then again, that's the beauty of TBN!
   / Brush Hog check chains on slopes. C of G better/worse? #22
Good points about the articulating geometry. The reason that hasnt been brought up is likely due the focus given by the thread title and the fact that most of us have no experience with this and have to imagine all the possibilities from scratch. :)
larry
Duane, thanks for your well thought out and informative post.
You brought out some advantages of using check chains that I was unaware of. I was hoping someone would comment that actually used them.
larry
Actually, very little attention was given to my actual question.
It was more about why I was using check chains in the first place, and that something must be wrong with my hydraulics.
By doing a lot of reading on this and other forums, I was already pretty much convinced to use check chains on my mower, but I didn't know if they would change the CG in a negative way on slopes.
I was hoping someone that had actually used them while mowing on slopes, or had a convincing reason why they shouldn't be used on slopes, would post an answer.
So I guess I'll make some check chains up and use them on other parts of the property, and when I get to the steeper parts make a determination then whether to unhook them or not.
Thanks everyone for your comments. :thumbsup:
Wooden Dump Barge Wagon (A50515)
Wooden Dump Barge...
Woods Brush Bull 7' 3 pt Mower (A50514)
Woods Brush Bull...
IH Cub Lo-Boy 154 (A50514)
IH Cub Lo-Boy 154...
2011 INTERNATIONAL PROSTAR +122 6X4 DAYCAB ROAD TR (A51243)
2011 INTERNATIONAL...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
