Traction I got stuck
/ I got stuck #1
Nick359
Huron, OH
JD 4720
I was on vacation this week. I was going to dig geo therm trenches, but I didn't get the parts to get started. I thought I would work on the pond. I did get some work done, but the tractor didn't want to leave. I backed into the area and dug. When it was time to go, the outriggers didn't want to let go of the ground. I had to get the Toylet with the rear winch to get the tractor out. I broke my new mirror off the truck, but the cage saved the door.
/ I got stuck #2
Thats what I'm talking about! Even though its not fun getting stuck. Hats off to you for being brave enough to enter that area.....looks very soggy.
/ I got stuck
I dug the slop on either side of the tractor out of the pond. When I went to get the truck I could see light under the front axle. The rear was sunk. Twenty minutes later the mud was halfway up the front axle housing. It was starting to get dark, and I thought it might spend the night in the woods. I had been cutting my new neighbors yard for him until he got a mower. I called him and asked for a hand. I guess friendships are forged in knee deep mud.
/ I got stuck #4
A true friend sin't the one you call to bail you out of jail, a true friend is in there with you
/ I got stuck #6
Next time, get a chain tie it to your backhoe and to a strong tree and start pulling with the back hoe.
/ I got stuck #7
Which way did you have to go to get it out? That looks like sticky mud! Did you have to chain the truck to something to winch it out?
/ I got stuck #8
Given that the pond is in that direction, that probably wouldn't have been the solution in this case. But the same concept would have worked up front. Chain the bucket to a tree, then work your way out by curling and uncurling the bucket.
//greg//
/ I got stuck
I had to get the tractor out by going forward uphill. I got about ten feet forward by using the front bucket and the hoe. After that I couldn't get anywhere and I was sidehilling towards a tree. I coudn't lift the rear of the tractor with the backhoe. I will have to see if I can lift up the machine in the yard.
I was in the same spot earlier in the day and I had no issues. We got a little rain and I went back. I didn't think I could get stuck with the hoe and loader, but I did.
/ I got stuck #10
Maybe good walking stick w/sharp end for testing. ;)
/ I got stuck #12
I know how you feel brother!!!! The rest of this picture would show two Ford superduties buried right behind the tractor. Gotta have respect for the buddy that gets stuck trying to help ya out!!! I'm glad it all worked out for ya.
/ I got stuck #13
Deja Vu!
10 days ago, I started across a spot that only looked a little wet and quickly found out how deep a mud bog can be after a bitter winter. The FEL only goes so far down and had a neighbor who first tried to pull me out and went back for his block and tackle. I will no longer drive over a wet spot in Spring!
/ I got stuck #14
Most people with any time on a tractor have a "got stuck" story. I do of course. Using a JD4700 with FEL and 6 ft bush hog I got into a swamp I had mowed through many times but there was this one section ... you can guess the rest. In right up to the axle housings. I was able to lift the front end with the bucket and place old fence posts under the wheels but not the rear wheels. Lifting the hog just sank the rear tires deeper. Finally inched it out about 6" per pull by curling the bucket back toward the tractor. The bucket pulled me out. That is with 17" wide tires on the rear ...
One wonders how people ever got by in the days when they only had 2WD tractors!
I am very surprised that the truck and winch were able to get you out back in 2011 -- just realized this is an old story being publicized by TractorByNet.
/ I got stuck #15
This is the closes I've ever been to stuck on the ole 2630
/ I got stuck #16
It all went down hill with the first sentence. If you had been at work it never would have happened!!! lol
/ I got stuck #18
My dad was trying to pull a ranger out and ended up like this.
2021 John Deere 1023E Tractor Loader (A63116)
2021 John Deere...
2017 Chevrolet Cruze Sedan (A61569)
2017 Chevrolet...
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
2001 Challenger 35 ton Flatbed Lowboy Trailer, VIN 1W8B21D261S000473 (A61166)
2001 Challenger 35...
(INOP) 1991 INTERNATIONAL 4900 6X4 DUMP TRUCK (A62130)
(INOP) 1991...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
