Loader Fel - 2x2 vs 4x4
/ Fel - 2x2 vs 4x4 #1
tracterorizer
Kabota mx5100
Tomorrow (sat) I'm buying my first tractor. It is a kabota mx 5100 2x2. I up graded (pre purchase) from the l3400 4x4 after reading on here about a lack of robustness of the pto system since I intend to set a lot of posts in hard ground. When I told the salesman I was switching up he asked if I was going to do a lot of Fel work and went on to say that with 2 wheel drive the balance if sketchy, but upgrading to 4 wheel drive would help. I asked if there was another cheaper ($2,000) option like weighting the back. He seemed to think 4x4 was the best way to balance Fel work. My question; is this just an upsale. Thanks in advance.
/ Fel - 2x2 vs 4x4 #2
Welcome to TBN. You'll find plenty of information and hopefully some good advice here.
4x4 on a tractor the size of an MX5100 is the real deal if you will be doing loader work. Here's why. You've got a tractor that weighs something in the 6,000 pound range, including the loader. Maybe a little more depending on what kind of implement you have on the back. And you have a loader that can lift roughly 2,000 pounds, or 1/3 the weight of the tractor itself, sticking several feet out in front of the front wheels.
That throws the balance to the front and off of the back wheels, where a 2wd tractor has its traction. Now you can start hanging lots of weight on the back to bring it back in balance, but the overall tractor is getting even heavier and harder to handle. And you still have a bunch of weight sitting on the front axle doing nothing to add traction.
With 4wd, all that weight, both front and back will be carried by a drive axle.
Many people say a 4wd tractor will be about 20% more effective than a 2wd one of the same size and power. I don't know if that's right or not, but I can absolutely tell you my tractor will do twice as much loader work running in 4x4 mode vs. 2wd mode. You dig harder, go better, stop better, climb and descend hills better, and have more control over the load being carried. And the 4x4 will go in wet or slick conditions where the 2wd will dig ruts and mud trying to get traction.
A 2wd tractor can do loader work, absolutely, but it's not even in the same league as a 4x4 of the same size. Also, it's a bit different story with bigger farm tractors (say, 100+ horsepower). They have so much weight that adding 4x4 isn't quite so essential.
Well, that's my opinion, anyhow. Hope it helps.
/ Fel - 2x2 vs 4x4 #3
I don't feel like it is just an upsale. Every time I do any FEL work I find myself reaching for the 4x4 lever. Yes, it can be done in two wheel drive, but I find I can drive a little farther into the gob pile, get more into the bucket, and generaly do the job safer and faster in 4WD. You definatly want 4WD if you need to go down hill with a bucket full. I find that even with the tiller or backhoe on my BX the back end is a little light with a full load of rock or mud on a down hill slope. Think, no brakes, rear wheels want to slide in 2WD.
/ Fel - 2x2 vs 4x4 #4
I have a 2WD M4900 with a loader. Get the 4WD. At times I lose traction on flat ground with a bucket load. I also filled the back tires. I run into situations often where 2WD just doesn't cut the mustard. Just get 4WD and be worry free.
/ Fel - 2x2 vs 4x4 #5
No matter if its a 2wd or 4wd, loaded tires, wheel weights, & 3pt weight are just about a requirement, if you want to get any thing done. The 2wd will need more weight, and split brakes help at times.
/ Fel - 2x2 vs 4x4 #6
In my opinion, for most, it is not an upsale, but rather valuable addition that will help when using your FEL. My father in law bought a new 2WD Massey Ferguson 375 and 2WD GMC pickup when he retired in 1986. Less than two months later, he traded the MF in on a 4WD 375. He kept the truck a couple more years and got a 4WD. He never owned another 2WD truck or tractor.
We own some older 2WD tractors without FEL's we use in the flat lands. I tried them on our hill farms and won't do that again.
Take some time and read some old posts using the "search" feature as I doubt any of us can say anything that has not already been said pro and con, here are just a couple. Good luck.
http://www.tractorbynet.com/forums/...isons/184399-should-front-loader-4-wheel.html
http://www.tractorbynet.com/forums/attachments/182437-front-end-loader-2wd-tractor.html
/ Fel - 2x2 vs 4x4 #7
I've done mostly FEL work with mine in the last few months. Even on my lawn I find times when I have a full bucket and cant get going in 2wd. The result is torn up patches from a single spinning wheel. Get the 4wd - you will be happy you did!
/ Fel - 2x2 vs 4x4 #8
Do yourself a favor and get the 4WD. It will save you time and time again. You didnt say where you are from but if you have hills 4WD makes your work much safer. You will retain control much better going down slopes especially if you have a FEL loaded it will remove the weight from the rear and a 2WD the rear s will likely slide. :thumbsup:
/ Fel - 2x2 vs 4x4 #9
Def. get 4WD...mine`s in 4WD nearly all the time. My land is flat and mostly cleared...and the few times I`ve tried it without was a lot less efficient.
Well worth the extra money:thumbsup:
/ Fel - 2x2 vs 4x4 #10
It really depends on where you will use the tractor. First off you will need weight in the back, either loaded tires and/or a ballast box. A ballast box you can make, I used a 55 gallon drum full of cement. If where you will use your tractor has pretty good grip then 2wd will work just fine.
My Case Backhoe is 2wd and while it can almost lift the rear off the ground only if conditions are muddy or if I'm trying to back up a hill with a full bucket will traction be an issue. Even then I can just lock the rear diff for extra traction.
That doesn't mean 4wd is not a real nice thing to have. If you will be going down hills with a loaded bucket then you could find yourself out of control. Most tractors don't have front brakes so if your load is trying to lift the rear wheels off the ground then stopping can be a real issue.
/ Fel - 2x2 vs 4x4 #11
Another thing to think about: it will be easier to sell your tractor if it is 4x4. Not that you are planning to sell now, but your needs may change - you may want something bigger or smaller and having cash from a quick sale always helps make the next purchase easier. Where's JohnThomas when you need him?
/ Fel - 2x2 vs 4x4 #12
In the 6 months i have owned my current BX1860V it has stayed in 4wd about 90 %of the time even with loaded rear tires. Get the 4 Wheel Drive. Very easy to shift out if you do not need it, but it is invaluable when you need it!
/ Fel - 2x2 vs 4x4 #13
4x4 is a big plus for both getting work done and for safety.
If I am working anywhere near a steep drop-off, even a trench or retaining wall, 4WD is engaged just for the extra braking power. Even on pavement. I can buy new tires for less than the cost of a rollover.
The salesman is right, a 2WD tractor will have much less resale value.
The other day I was carrying mulch up a very steep driveway, maybe 20% slope. I was much more comfortable in 4WD than 2WD, even though I didn't have more than 500 lb in the loader.
/ Fel - 2x2 vs 4x4
Thank you for all the replies. They were a great help. They in fact swayed me to go 4x4. I ended up getting a mx 4700 so the whole change only pushed my total price up 1k. It didn't take long (first hour of operation )to see you were right. Thanks again
/ Fel - 2x2 vs 4x4 #15
Good decision on the 4x4... and nice tractor, that MX4700! Please enjoy and be safe! If you care to share, new tractor pictures are always appreciated on TBN.
/ Fel - 2x2 vs 4x4 #16
Glad to see you got the 4x4. life is too short to go without it:thumbsup:.. especially in a new tractor. Sure the 2wd can do a lot of work, especially in the bigger heavier tractors, but in the size you are talking about.. 4x4 rules.
James K0UA
/ Fel - 2x2 vs 4x4 #17
I was mowing my lawn yesterday with my bx23 and had to put it in 4*4 when I was turning and going up a hill. The tractor didn't want to move with just one back wheel engaged. I Moved the lever to 4*4 and drove right up. Its indispensable.
/ Fel - 2x2 vs 4x4 #18
Congratulations and as mentioned, you have to post pictures, I think it is in your TBN handbook, page 6 paragraph 3.a under "If you don't have pictures, it didn't happen".:laughing:
/ Fel - 2x2 vs 4x4
Here it is, still new int the box. Mx4700 4x4, 6' box blade, 6' brush hog, and a phd.
/ Fel - 2x2 vs 4x4 #20
Very nice tractor, I wish they made the MX Series in a cab.
Hyster 50 5,000lb Propane Forklift (A64553)
Hyster 50 5,000lb...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
28ft. TV Tower (A65640)
28ft. TV Tower...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
213138 (A64276)
213138 (A64276)
Cattle Feeder (A65640)
