Electrical Schematic for MF 1035
/ Electrical Schematic for MF 1035 #1
iloveketchup
Member
Hinomoto E324
Hello, I'm new to tractorbynet.
Does anyone have an electrical schematic for a MF 1035 (or any close 1000 series)???
I bought an odd ball Hinomoto E324 and it has the same Toyosha 92ci diesel engine.
I ran the tractor at the seller's place, got it home, took it out in the woods, dropped it back at my place, but when tried to restart i heard some kind of faint click and couldn't get the tractor to turn over again.
All the gauges when turning the ignition key to the right would turn "on" meaning fuel, engine temp. Now they're just dead.
I'm wondering if that something was a fault in the ignition switch itself but would like to trouble shoot from it to the starter solenoid and neutral safety's.
The neutral safety appears to have been disconnected however i hear there is multiple. If any lever needs to be in a specific spot on this or similar engines, i'd like to know.
Sorry if this is in MF and the labels say Hinomoto, but again, same engine and electronics.
Photo of the tractor (repainted red).
/ Electrical Schematic for MF 1035 #2
Bad ground wire. Double check. If there is power and you hit the key and it goes dark it's usually a bad terminal wire.
/ Electrical Schematic for MF 1035 #3
could also be a bad connection at the battery check and clean all of your electrical connections and you should be fine
the negative post was loose. I felt pretty stupid but i assumed it was tight from the previous owner.
Now the clutch... kaput.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65053)
KNOW BEFORE YOU...
New/Unused SDLL60 Mini Track Loader (A65583)
New/Unused SDLL60...
Corral Walk-through Gate (A66408)
Corral...
2014 Chevrolet Express Shuttle Bus (A64556)
2014 Chevrolet...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
