Danimal
I just picked up a Ford 1700 4WD that has been sitting for about a year and a half. Story goes the PO was rototilling the neighbor's garden, brought it home, parked it in the drive and started to take off the injector pump but didn't finish. Unfortunately, he was elderly with dimentia and alzheimers so there wasn't a clear reason behind it. He got worse and eventually passed away.
Another guy picked it up via an estate sale and swapped it to me for an old Chevy truck I had. My sons and I got the parts, pulled the timing cover off and got things lined back up. Fuel lines were located in PA and shipped in and this afternoon the boys got it fired up following instructions on how to bleed the pump found on this site (thanks!)
Problem is, there is no throttle response, it just runs at WOT and is dumping a ton of fuel in. The only way to shut the tractor off is to turn the fuel tank valve off and let it starve. Black smoke pouring out the whole time.
We are going to pull the end cover off but would like to know what we might need to be looking for. Does anyone have an exploded view of the pump? The shaft is turning with the throttle arm so the rod isn't stuck. I don't know much about diesels and made the swap for this tractor because I got the rototiller with it and figured I could let my two FFA boys mess around with a simple diesel.
Your help is greatly appreciated.
