Just noticed an issue with the loader lines on DK45
   / Just noticed an issue with the loader lines on DK45 #1
grsthegreat
Super Star Member
north idaho
Kioti DK45SE hst cab
I removed my loader the other day to do the 50 hour maint, and i noticed some minor scratching happening on the gray engine cover and the hood on the side that has the hoses.
After i reinstalled the loader, i watched as i raised it to full height and lowered it to the ground... guess what. The hoses are rubbing on the metal.
This sucks. I tried ziptying the lines, but they need too much travel and movement. The zip ties snapped.
Guess its time to put on my old thinking hat. I cant leave it like this. if theres already scratches after 2 months...what will it look like in 2 years.
   / Just noticed an issue with the loader lines on DK45 #2
...what will it look like in 2 years?
Like a used tractor. I mean what are you worried about? The scratched paint or the rubber lines?
I don't think they rub on mine but I'll look again. I guess that if the lines are rubbing it would be a design issue or maybe they are too long or something.
im worried about both really. there mot too long, at full extension there tight.
I think i know what ill do to fix it. will play with it today.
   / Just noticed an issue with the loader lines on DK45 #4
I suppose a bungee cord might work.
I'm of the same mind as 02batsea--scratches will happen. Gives a tractor a nice personality and shows it's doing some "real" work instead of just mowing a lawn. :)
I have the same attitude for my truck whose bed is quite scratched up from actually hauling things.
i tried bungee cord..nope. didnt work
its not that im against scratches, but i try to prevent them from happening for as long as i can. Do it with my trucks as well. my 2004 f350 has only 1 minor rock chip. its amazing what care and wax can save.
ok, its probably just me being ****, but i had to fix this issue.
Was actually pretty easy to do...took about 1.5 hours. I removed the loader support arm on the right side and installed a 1/2" diameter rod to work as a guide for the hoses. Works slick, and the lines no longer rub on the tractor metal. They also no longer contact the latch pin .
I noticed that the hoses were rubbing on the loader latch pin. this could of caused wear and tear no the hoses over time.
Now i just wish i could get a better match for the paint.
   / Just noticed an issue with the loader lines on DK45 #7
Kioti dealers sell spray cans of the orange- yours is the second generation paint color. Also can be bought by the quart, etc. I used automotive hardener to add to the paint when my body man repainted my damaged DK-35 hood.
There should be a hose protection sleeve fitted over your hoses to keep the chafing from happening- is there anything on them?
   / Just noticed an issue with the loader lines on DK45 #8
[if the hoses dont swivell then just turn the nut a bit until the hose lines up without rubbing ,,,,,,,,,,,,,
mine have the sleeve, but it was causing scuff marks anyways. its only 2 months old.. there was nothing to swivel. they go straight into the couplers.
when i raised and lowered the loader, the hoses were rubbing during the entire operation.
Now they don't get within 1/2" of the metal.
   / Just noticed an issue with the loader lines on DK45 #10
I looked over my DK40SE yesterday, and couldn't ID the problem spot (couldn't find any scratches or rubbing of hoses). That was before you posted photos though, I'll take a closer look today.
I'm only at 26 hours though so maybe I'll notice it later.
2021 Caterpillar 300.9D Mini Excavator (A55973)
2021 Caterpillar...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2018 FREIGHTLINER...
2020 Chevy Silverado (A56435)
2020 Chevy...
2008 CAT 305C (A53317)
