Enormous Stump disposal? Most cost effective method?
   / Enormous Stump disposal? Most cost effective method? #1
SrChf
Edgewater, MD
None...YET!! :)
Hi folks.
Few weeks ago I had a guy dig out a bunch of enormous stumps for me with a JD310. all but one enormous tulip poplar he managed to not only dig out, but push/roll/drag off into a ditch in a back hidden area of my 5 acre plot. Our time was up on the machine and I was left with this humongous tulip poplar stump sitting in the front yard. Its up out of the ground just sitting there ruining an otherwise nice view.
I dont want to rent that JD310 again just for one stump - that's $500.
This root ball is so heavy (lots of clay soil clinging to the underside of it) and massive (easily 30 feet in circumference) it does not even budge a centimeter when I try and yank it with a chain hooked up to my F350 (tires just skid on the asphalt).
I have a big STIHL 660 w/ a 32" bar, but I cant cut it up into smaller bits, at least, not without ruining my Bar and chain.
Cant burn it as it is near another tree - not that this wet thing would burn anyway after the accelerant cooked off.
Only other 'tool' I have is a BX25TBL but this thing outweighs it probably 10x over. I'd probably have to cut it into 8 pieces for this tiny thing to be able to help.
Thoughts? Suggestions?
   / Enormous Stump disposal? Most cost effective method? #2
I had nothing this large but I did have a stump that probably weighed 1000 to 1200lbs. I power washed all of the dirt off of it and let it sit for a year after which the loader on my JD2210 could just lift it. I took it out back and buried it.
   / Enormous Stump disposal? Most cost effective method? #3
Wow, that is a huge stump. I have no idea if this suggestion is a good one but could a stump grinder guy come and at least reduce it to a manageable size? Can you dig a hole beside it and push it in and bury it? (I know, why bury what you just dug up but I'm trying to be creative :confused2:)
   / Enormous Stump disposal? Most cost effective method? #4
Most cost effective would be to let it rot and save your money.
   / Enormous Stump disposal? Most cost effective method? #5
Pressure wash it and use your chainsaw
   / Enormous Stump disposal? Most cost effective method? #6
drill a hole ... black powder and stand WAY back... :thumbsup:
I could dig a hole big enough with the BX no problem, but since I have nothing on site that can even move the beast 1 cm, its a non-starter.
Sounds fun but my house (and windows) are maybe 30' from the stump. My luck i'd throw a massive chunk right through a wall.
Forgot to mention, wife is a photographer and has a studio on site, so customers come and park in our front. Ma'ma says the eyesore has to go soon.:(
I have an (electric) pressure washer but its prolly way under powered, not to mention I can only reach the perimeter soil. the stump is sitting upright with the majority of the dirt underneath, out of reach for even the best of power washers.
(INOP) 2014 DEERE 210G LC EXCAVATOR (A51242)
(INOP) 2014 DEERE...
John Deere 643 Corn Head (A50514)
John Deere 643...
HELI STRAIGHT MAST FORKLIFT (A51242)
HELI STRAIGHT MAST...
Killbros 250 bu Gravity Wagon (A50515)
Killbros 250 bu...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
VOLVO L45G RUBBER TIRE LOADER (A51242)
VOLVO L45G RUBBER...
