It is possible to hit the stabilizer...
/ It is possible to hit the stabilizer... #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
On a BX24: Every time I see the sticker on my backhoe stabilizer that says something along the lines of "It is possible to hit the stabilizer with the backhoe boom," I scratch my head. It doesn't seem any more possible to hit a stabilizer with the backhoe than it does with the loader. What's the deal with this warning?
/ It is possible to hit the stabilizer... #2
Kubota's fondness of warning stickers. :confused2:
I guess it could happen with a much wider bucket...
/ It is possible to hit the stabilizer... #3
I haven't tested it, but it doesn't seem possible with the standard 12" bucket.
/ It is possible to hit the stabilizer... #4
It certainly is possible on a B21 with the 12" bucket.
Have you tried trenching sideways? I try to avoid it when possible but to connect trenches or in tight quarters I do so. I have touched the stabilizers with the bucket teeth.
/ It is possible to hit the stabilizer... #5
The BX doesn't swing as far as the B21, and the outrigger pads are smaller. The 12" bucket on the BX won't hit, as far as I can tell.
Perhaps it's just a standard issue sticker on all stabilizers, although I hadn't thought about the possibility with a larger bucket. Considering Kubota only offered a 12" and 8" bucket (I think), my guess is that they weren't thinking that.
/ It is possible to hit the stabilizer... #7
I have a woods 7.5 and when working 90 degrees to the right or left you can hit the cylinder and more.I cleaned out my greese fittings two tmes before i welded a 2 inch tall section of 1.5 inch pipe around them to protect them .
/ It is possible to hit the stabilizer... #9
Don't know why not; I have hit most everything else: wife's favorite Dogwood, golf cart, pump house, etc.
/ It is possible to hit the stabilizer... #10
:thumbsup: on all backhoes that I have ran if you try hard enought you can tear anything up including the staliziers. Any yes at one point I did have a bx24 although it was small it could create large problems if I was not careful:D.
/ It is possible to hit the stabilizer... #11
The backhoe can hit the stabilizer on my Kubota L39 And I think it could on the Case 680.
And I know you can drop a rock that would definitely hit the stabilizer and ruin it.
Just watch and be careful of them.
Yeah, on the BX24, there isn't enough swing to hit the stabilizer. But there certainly have been times that I could have inadvertently damaged one of them by backhoe actions, as you (jmanatee2) mentioned. I guess it must just be a sticker they slap onto all stabilizers.
/ It is possible to hit the stabilizer... #13
its lawyer speak for : if it not posted, then any idiot will not get hurt or we won't be liable for any damage if we DO post the warning label "justs in case" :laughing:
/ It is possible to hit the stabilizer... #15
My L35 16" bucket hits my stabilizers. Like others said, almost all backhoes can touch the stabilizers. I know that many larger trackhoes will hit the cab your in if your not careful.
/ It is possible to hit the stabilizer... #16
My bx24 bh had a swing arc of 140' the bucket would not hit. My new b3030 has a swing of 180' very easy to hit the stabilizer.
