Is this a normal temperature while mowing?
/ Is this a normal temperature while mowing? #1
casolorz
Wichita, KS
Kubota BX1860
While mowing (gator mulching blades) on my bx1860 (loader attached), is this a normal temperature? It was a hot day, maybe 80s.
/ Is this a normal temperature while mowing? #2
I dont think so..I dont have a BX, but I am betting that the radiator is obstructed. Check it out closely for trash in the fins, or if it has a screen in front check that. That would be my first guess.
James K0UA
/ Is this a normal temperature while mowing? #3
I have a BX 2350 and that is not normal. Mine never runs that hot, even in 100+ temps. Check the radiator, the fins are probably clogged. I blow mine out regularly with the air compressor.
/ Is this a normal temperature while mowing? #4
Sure not normal for my BX2660.
/ Is this a normal temperature while mowing? #5
James K0UA
Do this...
I keep a 2" paint brush (bristles cut down to about 1/2" for stiffness) with me when brush cutting. And I clean the grills off periodically while doing that chore.
BTW, when the engine gets hot...do not shut it down! The block will act as a heat sink. Just disengage the PTO and let it idle at 1200-1500 RPM for a few minutes.
/ Is this a normal temperature while mowing? #6
That is where mine runs. The 60 series gauges seem to run on the high side, my older units run on the low side.
/ Is this a normal temperature while mowing? #7
My BX temp doesn't get that high, even when mowing on a hot day and engine at max rpm. I suggest you check radiator as others have said, also coolant level.
I guess I am going to check my radiator tonight.
/ Is this a normal temperature while mowing? #10
/ Is this a normal temperature while mowing? #12
BX's tend to run on the high side of the gauge when mowing on a hot day. Mine will get close to that high, but when mine gets that high, its time to clean out the radiator. Stuff gets caught in there, and it can be tough to get it all cleaned out.
/ Is this a normal temperature while mowing? #13
Probably your radiator screen is clogged. Under the hood between the 'firewall' and the rad just slide it up. I've seen mine that hot and it was when the dandelions turned to white fluff and when I finally pulled the screen out it was absolutely covered in them :p
So I cleaned everything I was told to clean, it didn't help. I also had my 50 hour service and they claimed everything is perfect but of course they couldn't reproduce the problem. What am I missing? What RPM should I be mowing at? Could there be some other kind of problem?
Same saga:
http://www.tractorbynet.com/forums/owning-operating/216864-bx1860-overheats.html
As an informational note, my BX1860/54 MMM/FEL has never had the temperature gauge up in the "near red" area shown in the first post in this thread.
Wrooster
I'm going to look into removing the battery and see if that helps although I would hope the dealer looked into that, but I guess it's always possible they didn't do anything and just said they couldn't reproduce it.
At what RPM do you guys usually mow? I have a 54'' mmm.
/ Is this a normal temperature while mowing? #18
I mow with the throttle wide open. I mowed Satruday, temps in the mid 80's, and my gauge got pretty high, just like your picture. I pulled the battery and blew out the radiator. There was a section of it that was clogged and you wouldn't see it without pulling the battery. It takes about 10 seconds to pull the battery so no big deal, you don't even have to disconnect the leads.
/ Is this a normal temperature while mowing? #19
That's about where mine sits on 80+ days mowing at 3k RPMs with my 48" MMM. I noticed it because just working with it (loader, blading, etc) it never gets above the middle. But mowing it does. No biggie.
I usually mow like at 2300 or 2500 or so which isn't full throttle. I have blown the radiator with my compressor, even taken the battery out although when I took it out I just looked because I didn't have my compressor with me but it looked so clean.
I think I'm going to have the dealer take a look at it again, as far as I know it has been getting that hot since I first bought it.
213141 (A64276)
213141 (A64276)
GATOR UTV (A63276)
GATOR UTV (A63276)
1998 MAGNUM TRAILER (A65643)
1998 MAGNUM...
2023 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59914)
2023 KENWORTH T680...
John Deere 7000 6R Planter (A66285)
John Deere 7000 6R...
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
