Maybe----Moving from a bota to a Kioti?
   / Maybe----Moving from a bota to a Kioti? #1
RadarTech
Elite Member
North Carolina
2007 Kubota L3400, YANMAR YT359C
Ok folks,
I spent some time on a Kioti this weekend and liked it..
It was a gear but still I think it does better than my larger bota..
It was a CK27...
What do yall think?
L3400 down to a CK27??
   / Maybe----Moving from a bota to a Kioti? #2
Why do you like the CK27 better? What does it give you or allow you to do that that kubota doesn't?
Just curious. Of course, I'm a Kioti fan! :thumbsup:
Well..
Let's see the loader on the 27 and 30 have better lift.
the 3ph has the crank for the right arm.. the stabilizers.. the telescoping 3PH arms..
Better cockpit...
higher capacity hydro pump..
now I think the ROPS is taller.. I don't like that...
When I looked at my Bota when I bought it, I wound up choosing it over the Kioti due to the "look" of the dealer.. and since then that dealer went out of business....
BUT... It has me thinking....
   / Maybe----Moving from a bota to a Kioti? #5
It depends on your needs, will the loss of HP hurt your work needs? Maybe look into a CK30/35 if you want the same higher capacities without losing the HP.
   / Maybe----Moving from a bota to a Kioti? #6
I got the Kioti instead of that exact Kubota for many of the same reasons. Plus it was cheaper and had a better warranty.
   / Maybe----Moving from a bota to a Kioti? #7
If I already owned an L3400, I'm not sure I'd take the cost hit to move to a CK, unless the quarter-inching 3ph was a problem for my tasks at hand. I also wouldn't want to give up any HP.
   / Maybe----Moving from a bota to a Kioti? #8
There is no 1/4 inching valve on that Kubota! Kioti offering it now?
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51242)
KNOW BEFORE YOU...
2007 PETERBILT  385 CAB AND CHASSIS (A50854)
2007 PETERBILT...
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
