Oil & Fuel Engine Oil question
/ Engine Oil question #1
Typhoon
Gold Member
Southern Illinois
LS MT357HC
Ok here is my question/dilemma. I have a Kioti DK40SE. My manual specifies to use 5W-30 weight oil in the crankcase. Normally I would use Rotella. However, NONE of the local auto part stores in my area have Rotella in 5W30. They all only have 10W40. So, my question... can I just run standard Pennzoil 5W30 in it? Or do I have to use a special oil just for diesels?? Anyone? Thanks!!
/ Engine Oil question #2
The short answer is that you need oil rated for diesel engines. Others will likely be much better at explaining the technical aspects. Don't use regular automotive oil, it will not serve your engine well.
/ Engine Oil question #3
Rotella makes 5w30 in synthtic. Do not use a oil not made for a diesel.
/ Engine Oil question #4
I have a 2011 DK45 SE HST and the manual states the following: (should be same for yours)
Engine oil
above 77F SAE 30, SAE 10W30 or SAE 10W40
32 to 77F SAE 20, SAE 10w30 or SAE 10w40
below 32F SAE 10, SAE10w30 or 10W40
i contacted Kioti last month, and they recommend Rotella 10w30.
i hear rotella has a 5w40 available, but is synthetic, expensive and hard to come by. Whatever yo get has to have diesel equivilent of CJ-4/SM oil (per Kioti customer service/tech support)
/ Engine Oil question #5
Is the 5w30 used year round? The lower the first number the better the cold weather startling. Yes, you most use CD oil for diesel engines.
/ Engine Oil question #6
well, a 5w30 would be better in real cold weather than a 10w30, but i am adding 2 electric block heaters to my tractor so i dont think its going to matter.
I tried for 2 days to find someone near me that could get the 5w40 synthetic...nope.
but the 10w30 is in stock and about $65/5 gal bucket. so i got that.
Also, the cc and cd specifications have been superseded with the CJ-4 specifications according to the Shell representative i spoke to
Shell Rotella T is a line of heavy duty engine lubrication products produced by Shell Oil Company. The line includes engine oils, gear oils and coolants. The oil carries both the American Petroleum Institute (API) diesel "C" rating as well as the API gasoline engine "S" rating. Ratings differ based on the oil.
Thanks for the replies guys. I figured that would be the answer. The guy at my local auto parts store, who by the way is the manager, and has worked there for years, had convinced me that it would make no difference if I ran regular pennzoil in my tractor, just as long as I ran the proper weight. But something still didn't seem right about it. I have always ran Rotella in my tractors. That's what I will stick with. I will just have to find it in 5W30.
/ Engine Oil question #8
why 5w30??? i think rotella only makes a 5w40 in synthetic ...thats what their rep told me.
he assured me the 10w30 would be fine in north idaho climate. i run 10w30 in both of my diesel trucks for years without a problem. oh, and regular oil would have trashed your engine. good thing you listened to your inner voice.
/ Engine Oil question #9
valvolene and napa make a 5w40 C rated oil.. synthetic and regular.. 5w30 C rated oil can be had in colder areas..
don't run an S rated oil in it..
soundguy
/ Engine Oil question #10
Synthetic oils are not expensive when you look at the whole picture. For example I just picked up a 5qt jug of Mobil 1 today at Walmart for my boat. Takes 4.5 qts. It was $24.50. 5 qts of regular oil was $14 but you can easily go 2 times as long on synthetic without worries. This makes the cost of the oil changed about $30 with filter. If you were to do 2 conventional oil changes it would about $40. So no, synthetics are not expensive, they are cheaper in the long run.
By the way I just picked up 10 gallons of Rotella 5W40 Synthetic at Meyer about 2 weeks ago for my neighbor at $17.99 per gallon.
Chris
/ Engine Oil question #11
walymart even has some syn as well.
soundguy
/ Engine Oil question #12
Amsoil makes a 5W-30 engine oil rated for diesels but Shell doesn't list anything of that weight approved for diesels under its Rotella brand that I saw on their website. If the manual says to run something, that's probably good advice.
Around here, it never gets very cold, so cold weather isn't of significant concern. Having said that, I run 5W-40 synthetic Rotella in literally everything (a bunch of motorcycles of all flavors, ATVs, 9 tractors, a riding mower, walk behind tiller, and my personal vehicles) and have never had a problem. However, the plural of anecdote is not data, so do with that what you will. :thumbsup:
The 5W40 is at my local Wal-Mart for around $20 a gallon. It's not as expensive as the smaller brand high performance oils, though. Since I do everything annually or more frequently, I could easily get away with 15W-40 for a few dollars less, but I have noticed that everything builds oil pressure more quickly with the 5W-40 vs the 15W-40; my stuff is expensive enough, and sits for long enough at a time, that it's worth it to me to build oil pressure faster rather than slower.
/ Engine Oil question #13
If Kioti recommends a 5W30, I assume they also sell that same oil at their dealers. Why not use that if you're in doubt?
Sean
/ Engine Oil question #14
Chris
remember, you can go twice as long as long as "ITS OUT OF WARRANTY". if you try that while its still under warranty...your hosed. if you cannot backup your oil changes with receipts for scheduled oil changes, your warranty is voided.
i found out that the hard way on a truck i had. i used synthetic oil and extended my oil changes. had engine troubles and ford voided my warranty service.
Here in No. Idaho, the synthetic is runing over 2x the cost of standard...not sure why. I cant even find it in stock at the tractor supply and fuel depots. Very odd.
/ Engine Oil question #15
Check Walmart for 5w40 Rotella.
larry
/ Engine Oil question #16
larry
one place i never checked was walmart...and seing as ill never step thru their doors, i guess ill never find it there hehe
oh well
Caterpillar 235 Excavator Service and Parts Manuals (A63117)
Caterpillar 235...
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
2012 Volkswagen Passat Sedan (A61574)
2012 Volkswagen...
