Changing Fuel Filter
/ Changing Fuel Filter #1
hunterridgefarm
Western NC
Kubota L3130DT, Kubota L185DT, JD LX277
I have a L3130 I am getting ready to do the 600 hour service on. One thing I have never had to change is the fuel filter. I keep one on the shelf but have never changed it since I don't see any water in the bowl or sediment. But I plan on changing it now. I have talked with the dealer and he said to turn the fuel off at the filter, which I see is just a couple of inches from the filter and once replaced fill the bowl with fuel before putting it back on. Once on turn the fuel back on, start the engine and rev it up for a couple of minutes and I should not have to bleed the lines.
So here is my question. does any one have a picture of how to take it off? It looks like you just unscrew the big nut holding the bowl in place and remove the bowl; correct...?
Since I have never done this I thought it would be good to ask first.
Thanks
David
/ Changing Fuel Filter #2
Thats pretty much it but it should all be in your manual.
/ Changing Fuel Filter #3
If yours is like my L5030, there is a procedure for bleeding the system involving rotating a valve on the pump, running the engine for thirty seconds after replacing and the turning it off and closing the valve. It is a simple procedure. Do you have a manual?
kevinj/TripleR,
I have a manual but all it shows is where the fuel filter is located. It does not give any kind of instructions for changing it.
/ Changing Fuel Filter #5
I don't have my Manual handy, but will find it and see if there is a picture and take a picture of it and post it with the instructions; may be a half hour or so.
/ Changing Fuel Filter #6
To bleed the system after changing filters:
Open the air vent cock on the side of the fuel injector pump.
Start the engine and let it for run for thirty seconds, stop then engine.
Close the air vent cock.
Let me know if you need anything else.
TripleR...Big thanks:thumbsup:
My manual doesn't show anything like that. I hope to change it this weekend if I get all my discing done.
/ Changing Fuel Filter #8
I recently changed my L4200's fuel filter for the first time after ~900 hours of operation on the same filter - no problems, just felt guilty. My tractor has a bleeder valve that you twist open while the tractor is running to purge any air in the lines - yours probably does too. Read about this in your manual (edit:as somebody already posted). I did not have to pre-fill the bowl, just screwed it on, turned on the fuel, and turned the key. Tractor started up instantly - I did the purge procedure, but I don't think it needed it.
One thing that NOBODY on this forum warned me about (or you so far...I think it's for the comedy) - when you pull off the filter, a good half-gallon of fuel is going to pee out, so have a drain bucket ready. Even better, catch it into something clean so you can dump it right back into the tank. I think it is under pressure between the filter and injectors - if your tractor has been sitting a while w/o running, it might not be as bad, but I don't know that for sure.
JayC
Jay,
Thanks for the headsup.
/ Changing Fuel Filter #10
They are really easy, I am sure there is a tool for the ring, but I just use a pair of Channel Locks and am really gentle with it so no marring. My manual say to clean the filter, but I just replace them and I don't fill the bowl. Be sure to check the rubber O rings.
JayC
I wonder if that is specific to that model as the only fuel I lose is what is in the bowl.
/ Changing Fuel Filter #11
just finished cleaning fuel filter on my 4 cyl K. genset...non-enclosed...
problems encountered
1. could not budge filter to turn either way
2. had to remove filter bracket
3. had to pound bracket to separate filter from bracket
cannot understand why the Japs put it on so tight.
anyhow, just wanted to share this with any others experiencing first time tightness
replaced with hand tightness as instructed by manual 232323232%7Ffp43865)nu=5237)262)235)WSNRCG=37365997;9326nu0mrj.jpg
Gradall no crank no start (A61568)
Gradall no crank...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63118)
2024 Kubota...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
48x4 Mini Skid Trencher (A63118)
48x4 Mini Skid...
2021 John Deere Z960M Zero Turn (A63116)
2021 John Deere...
